Hi,
My B234F has a very confusing itermittant cold weather issue.
Last year, in the extreme cold of maine in a snow storm my car had a strange issue where it could barely get past idle without coughing and fluttering like it was running out of fuel or something. During this entire issue the main fuel pump was humming good and strong. I replaced the fuel pressure regulator despite the fuel pressure being fine and the issue didn't happen again. Later i checked that the in-tank pump was working.
Later that year, the catalytic converter broke apart and clogged up the exhaust. When it failed the car could not rev past 4000 rpm, even in neutral. I then replaced the entire exhaust and the cat.
This year. I was driving to work on a very cold moring and i pulled onto the highway, hit 6000 rpm in second gear and the car was running strong. Later i tried to pass someone and the engine hit a wall at about 4000 rpm, even in neutral.
the first time it sounded like detonation or fuel starvation, but any time after that it sounded like the clogged cat did.
That same afternoon the car ran strong again.
Today i dropped and inspected the catalytic converter (which is not fun) and it is FINE!!!
So, what the hell could be causing my cold-weather specific intermittant power problem.
I just want to have christmas and go skiing damit!
Thank you much,
-Dana
edit: the car could hit 6000 rpm in neutral under light throttle, but under load it couldn't break 4000 rpm.
Thank you much,
-Dana
