drj434343
- Feb 22, 2010
- Portland, OR
After overhauling the suspension on my 1993 240 wagon, including replacing the sagging front springs with stock ride height IPD replacement springs
https://www.ipdusa.com/products/4923/106759-stock-height-coil-spring-front
I began to experience spring pop sounds from the front right strut when turning corners.
I've traced this to the top of the spring shifting in the top steel spring retaining plate, which sits just below the upper strut mount. It appears the ID of the spring is at least 1/4" larger in diameter than the inside lip of the retaining plate, allowing the top of the spring to pop back and forth in that slop. I can confirm this by grabbing the top of the spring while the car is sitting on the ground and manually popping the spring back and forth in that retaining plate, producing the same sound I hear while driving.
I assume IPD sells these springs sourced from another vehicle application that just so happens to be close to the Volvo requirements. I have never experienced this slop with an OEM spring.
Has anyone else experienced this issue with the stock ride height IPD replacement springs?
