olov
doing something stupid
- Aug 11, 2003
- warrenton, nc 27589
hey, i'm fixing to start hunting for a block and start a turbo engine build up. at first i was thinking of getting a block bored out and creating the max displacement, run somewhat high compression, and run somewhat high boost. not sure of these numbers, but i was thinking of a naturally aspirated compression and over 10 psi if i o-ringed the block, good gaskets, etc.
then i watched getaway in stockholm 2, and i started googled for the specs of the escort cosworth. what i get from the pages i read, is that it's basically an engine with a bore larger than it's stroke "90,8 x 77,0 mm", 16v, and the race version has an oversized Garrett T3/T04B turbo(T35). running 2.5 bar(is that over 30 psi?)and yes, i know it's got alot of turbo lag, and the power band makes it horrible for normal driving, and i'd have to get the best valve springs $ can buy. but once the huge turbo kicks in, it'll fly. and some of those cars were rwd. if it's possible to get anywhere close to the escort cosworth, it would be worth it. "Ford Motorsport claim a 3s 0-100 Km/h in any conditions (including gravel)!"
so my first question, was would it be worth it; time/$ for the performance? and are there parts for this type of build up? EricF posted about destroking a B21 back in 2003. would this be the ideal block?
thanks guys for the patience with this post
