GeneralBurrito
- Nov 22, 2017
- California
Walker has a 5 year/50,000 warranty though. Since the new cat was put in, I don't think I even out 2k into it. It's just a daily driver to and from school.
It's a 1987 240 DL, manual.
I still have the old single hole injectors that I could slap back on. They may not be as clean as the 850 yellows, but they still work.
Ok, I suppose that explains the 724ppm limit for NOx at 25mph then. My reference is early '80s cars which have slightly higher limits. There's no way of looking this up at all, other than comparing notes with other people's test reports.
For an 1983 240 DL w/ manual, here's an illustration of how NOx changed over time (well, up until late 2014 anyway when I made the graph).
you should convert to EZK, then you'd have the cleanest running 240 in the world!!!
I recall that post by Philski also. I would go with that.
High octane fuel helps too. I don't know how much Ethanol to recommend, but I would maybe try almost half of the fuel in the tank as E85.
Wait, how do I find what type of ignition I have?
Timing has to be in spec. But retard it as much as you can like i said.
They check static timing.
It's 12 +/- 2
Set the static timing at 10 degrees or as close as you can get using a timing light and rotating the distributor. Sometimes it's hard to tell. Verify idle speed too - there is a speed at which that acceptable timing range is defined by Volvo. Then prevent it from advancing by blocking off that vacuum hose to the ignition box with a BB in the end. Plug the hose back in so everything looks Kosher.
