BabyBlue240
- Jun 14, 2005
- Mountain View, CA
Posted this in my project thread but it'll probably get more views here.
alright, today i go to start the rebuilt b230ft for the first time and as would probably be expected with someone starting on Megaquirt, it doesn't start. pull out the plugs to check if its way flooded or something, and there's water, not gas, on the spark plugs, like if you slung it, drips would fly off, that much. take off the oil cap, and im heartbroken to see this:
now i just rebuilt the motor, it hasn't ever run since it was rebuilt. the block was decked and the head was shaved by the machine shop, and the place has a good reputation locally, so i don't think thats the problem. but i used a new elring head gasket and torqued the head exactly how the greenbook says to. i guess the water and oil could mix somewhere else (the 15g or the oil/water cooler that im using off the late 940's) but the fact that there's water on the plugs makes me think the problem is at the head gasket. it's so wierd though because like i said, it hasn't ever started, so neither the oil or water system has really gotten up to pressure, yet the oil still looked like this when i drained it. i mean i probably cranked it a total of 30 seconds over different trials before i discovered this.
i mean, it seems like something is REALLY wrong and im missing something because i dont see how that much water can get in the oil that fast. any ideas? its a real bummer.
