Murploid1
- Apr 6, 2017
- Houston, Texas
Car: 1982 244 turbo (kjet).
Today my car decided it did not want to idle - running VERY rich.
After checking all the basics; vacuum leak, fuses, o2 sensor, idle air controller, even replaced idle computer - nothing changed.
However, when I unplugged the harness from the ECU the car idled much better, it was running lean, but it did not splutter and die.
The frequency valve is buzzing, just not sure why its running so rich when plugged into the ECU? (AFR 9)
Wiring harness is good, I removed the ECU (I think its a fuel control unit?) and inspected it visually, looks fine, nothing burnt I can see.
Should I just replace the ECU? Or something else i am overlooking here?
Thanks!
Thanks!
