sloopy
2-digit whp
- May 25, 2020
- North Texas
Right. I forgot to mention I'm in a 240.
Adjustable dampers would allow me to adjust the suspension depending on the track's condition/layout in a better way than valved dampers would? But I could be wrong for sure about this!For a mostly track car either will work, but you will probably get the best performance from a custom valved monotube, be it Bilstein or something else. I've had a 740 with Koni yellows, and then with revalved Bilsteins, and I much preferred the ride with the Bilsteins for the street. On my 245 I have Koni race inserts in the front and Bilsteins in the rear, and it's a much stiffer setup overall but it works.
Just wondering, why do you want to have adjustable dampers? A great option would be to have dampers valved according to your weights and spring rates. I'd much rather have custom valved dampers than adjustable dampers with unknown valving.
When I priced them out Ben was cheaper than Summit. Are you going to shorten your strut tubes? Koni has a long and short insert. 8610s are single adjustable race and 8611s are double, but you need to figure out your lengths.Looks like it's gonna be Konis then. I'd like to find them local though since the CAD to USD exchange rate these days is like getting raped without KY... Anyone as the part# for the sport and race struts? I have nothing against Ben but $1300 CAD + shipping for a pair of Koni struts is a lot of money. I will buy his adjustable strut mounts and quick steer roll correction parts though.
I bought a set of used Kaplhenke front coilovers from a guy in Montreal. The struts inside were shot. They're at the machine shop right now to get sandblasted so I can't measure them.When I priced them out Ben was cheaper than Summit. Are you going to shorten your strut tubes? Koni has a long and short insert. 8610s are single adjustable race and 8611s are double, but you need to figure out your lengths.
If you know how to tune dampers for performance, and know what you want to adjust inside the damper and why, then yeah, they can be great. But if you don't know that, non-adjustables tuned for your specific car by someone who does have those skills will be better.
You are actually the lowest on the prices. Sellers in Canada are selling these for $625 per unit + shipping and taxes. So the total comes out at around $1400 CAD minimum.I think you will be fighting the exchange rate no matter who you buy from because AFAIK Koni doesn't import directly to Canada; everything will most likely come from Koni-NA, which means someone along the line is paying the currency conversion... whether you see it directly or not.
It is a lot of money, the strong US dollar has really kneecapped my international sales.
He said there is a limit to how many times you can revalve a bilstein insert because you cut a crimp and re-crimp it closed, making the insert shorter.
What car, what's the sprung and unsprung mass? With that basic info you can get anything revalved that will work for your intended purposes. Also, that spring rate seems really high, even for a lowered vehicle.OK so let's answer a related question while we're here.....suppose you had 550-600lb/in springs on the front end, what dampers would you run then?
Part 2, I'd like to lower the car a bit more than the stock strut length allows.
you just have to open up your wallet and max out the credit cards
really tight 2-way lsd.
