Venlonaer
- Dec 9, 2014
- The Netherlands
Hello people, some may be more acquainted with me (as Kristian Vobla) from the TB facebook group since I'm very active there but I don't post a lot here, mostly just lurk for info.
I own a 242, a p220 amazon wagon and a 940 and like to document my progress/upgrades and so on so here goes.
11 months ago I bought a 940 as a successor for my '75 frankenstein 245. After 2 years of hogging around in the 245 I wanted more luxury, power and handling.
This was my 300k km 245 which reliably served me for 30 thousand km;
I put up a request in a dutch Volvo marketplace facebook group with the following criteria;
- LPG
- Turbo
- M90 gearbox
- Sunroof
- Climate control.
Other stuff like leather seats would be something for later but I especially missed the airconditioning + sunroof from my '86 740 GLE and power my B21 BW35 combo was seriously lacking
I've owned 5 na bricks before this and I'm looking for something quicker (or less sluggish
The 940 I picked up for a mere 1000€ had been sitting for a year and was destined to be a parts car (mainly for the B230FK + M90 combo).
It had everything I was looking for + leather seats, car history and maintenance held up as of 100.000 km until 509.000 km!
The car was partly disassembled, mounted the fenders, hood, headlights and it needed a new battery + I brought my own wheels. Then we finally were headed home.
I noticed the car was stuttering. It stuttered more on LPG than gasoline, so it would be something ignition related... at home I noticed sparks jumping outside the distributor cap. Put on the new distributor cap and the car ran perfectly, very happy... was worried it would be something more grave.
While I was at it I cleaned the engine bay, there was like 2mm of dust EVERYWHERE since the car was stored for over a year without a hood....unfortunately didn't make a before picture but just imagine everything had the same dusty finish as if it was molded from 1 part
To pass the annual vehicle inspection it just needed a brake hose done and an exhaust without holes.
I bought an eggcrate grille and clear corners, plastidipped the chrome surround black and also slapped on prancing moose stickers.
Shot a final picture before I sold my 740 last summer.
So far the introduction.
I've never really paid attention to my dailies but driving and maintaining them when stuff needed to be done to keep it driving, this car is going to be different.
My plans:
Suspension:
- BC racing coilovers
- Superpro polyurethane bushings errywhere
- Viking fabrications adjustable torquerods
- Adjustable (OEM customized) panhard rod
- Sway bar upgrade
- Strut brace
- Subframe brace
Braking system(front only):
- 302mm Volvo 850 upgrade
- Zimmermann perforated and ventilated discs
- Stoptech braking pads
- Motul RBF 600 braking fluid
- Stainless steel braided hoses
Exterior and interior:
- Fix minor rust
- Replace dented rear passenger door
- Wrapping the car nardo grey
- Swap the grey interior to black
- 'Wood' trim
- Fancy steering wheel
- New floor mats
- Cupholders(!!!)
- Fix broken interior lighting
- Fix broken heated seats
- Fix damaged leather seat upholstery
- Slap on a 740 front end and other little bits
- Snowcap
- OEM spoiler
- Addon kit for 740 (h8rz gon h8)
- Get the correct passenger side taillight
- Remove roof rails (slicktop)
Other:
- Keyless entry
- Get the airconditioning (ECC) working
- Install a trailer hitch
- Upgraded audio system (better speakers + adding a subwoofer)
Engine and driveline:
- Rebuilt engine /w new pump, all the belts, oil trap etc etc etc.
- Fix sloppy engine and transmission mounts
- Fix the oh so extremely annoying driveshaft vibration...u-joints and driveshaft support bearing probably
- M90 dual mass to M47 single mass conversion
- Replace the M90 with a good one (main input shaft bearing noisy)
- Install a LSD
Planned setup:
- 19T /w angled flange
- 440 cc/min Bosch Greens
- Vialle V28 injectors
- Do88 intercooler + piping
- Slightly ported 531 head
- VX3 cam
- Buchka wasted spark
- 3'' AMM
- 3'' 960 throttle body
- 3'' downpipe
- 2,5''/3'' catless exhaust /w 1 silencer
- 6 puck KL racing clutch disc
- Reinforced pressure plate
- Stainless steel braided clutch hose
I'm aiming for 270 horse ~ 350 Nm at the wheels.. main limitation being the LPG fuel system.
Couple of the things on this list are already (partially) done, I'll update soon but I think I first need to resize my images ....
- LPG
- Turbo
- M90 gearbox
- Sunroof
- Climate control.
My plans:
Suspension:
- Sway bar upgrade
- Strut brace
- Subframe brace
- Fix minor rust
- 'Wood' trim
- New floor mats
- Cupholders(!!!)
- Snowcap
- OEM spoiler
Other:
- Keyless entry
- Install a LSD
Planned setup:
- VX3 cam
- 3'' AMM
- 3'' downpipe
