paulcurran
- Feb 27, 2005
down to the last few wires on my LH 2.4 conversion on a 1984 240 Turbo. This car had been already converted to 2.2.
I got my lh harness & some components from a 1992 240, it has an 11 pin connector. Just got help from dbarton & sbabbs on a couple of harness questions but still have more.
First is where to connect the thick yellow/red wire. in the 92 240 fuse panel diagram it shows this wire to go to the input side of fuse 4, the output side shows to y/r to O2 sensor & in tank pump.The y/r thick wire comes from the fuel pump relay, I believe. The 1984 shows this wiring to fuse 5. Make sense to connect this thick y/r the same way? Some threads show this wire to a switched fuse? Someone has put a single in tank pump in this car, that wire comes from the same y/r output wire. Don't see the main pump wire doing anything.
Can the blue wire that needs to be switched go to an appropriate fuse, or is there an advantage to put it to 15 on the ignition switch, whitch looks like a PITA to do?
Long way to ask simple questions which probably have easy answers, just want to get it right.
Thanks, Paul
Thanks, Paul
