bobxyz
- Aug 29, 2014
- Boulder CO
K-Jet to LH2.4 Details
Here are the main items I needed to convert from K-Jet to Turbo LH2.4
Parts:
- LH2.4 wiring harness and main relay.
- Turbo ECU (cold start injector control needs to match intake manifold setup).
- Turbo EZK (non-EGR unless you're going to install EGR from donor engine).
- EFI Intake Manifold with injector rail, FPR, and throttle body. Earlier setups include a cold start injector, later versions eliminate it.
- Throttle cable and kickdown cable (if auto) for throttle spool on EFI intake.
- Turbo, hoses and turbo exhaust.
- Intercooler, mounting brackets, and electric fan or increasingly rare turbo fan shroud.
- LH2.4 IAC and hoses. There are at least 2 versions of 940T hoses - those for top-outlet intercoolers and those for center-outlet intercoolers.
- Cone air filter and tubing, or Turbo K-Jet air filter&box plus gutted K-Jet fuel distributor and rubber cobra intake hose.
- Low impedance original Turbo Injectors and resistor pack, or high impedance injectors with similar flow rate (no resistor pack needed).
- EFI head, or plugs for K-Jet injector holes (DIY or STS machining).
- LH2.4 MAF and extension wires/harness to relocate MAF from left to right side of engine compartment.
- LH2.4 Distributor, ignitor (power amplifier), coil, CPS and 60-2 tooth flexplate or flywheel.
- Knock sensor, LH2.4 coolant temperature sensor,
- Original Log turbo exhaust manifold or 90+ manifold, and matching 1-wire or 3-wire O2 sensor.
- "TP32352-1 1993 240 Wiring Diagrams.pdf" or similar LH2.4 greenbook.
Machining (click on pics for full size):
- If you're converting to turbo, you'll need to drill the block for the turbo oil drain, or add a fitting to the oil pan, plus tapping off the oil galley for oil feed (there are lots of old treads on this).
- You'll need to drill and tap the edge of the B21 block bell housing for a custom CPS bracket: M6 thread, 1.575" center-to-center, ~0.91" hole depth, centered between trans bolts. Shown below is a '83 B21FT bellhousing (no CPS bump-outs) versus B230 bellhousing (with CPS bump-outs), and B230 CPS bracket:
- You'll need to notch your transmission to clear the CPS - if not pre-notched, you can cut out and file the CPS notch in the older bell housing. Not as strong as the later housing with the factory cutout, but OK for my needs:
- You'll need to make a custom CPS bracket - due to the thinner B21FT bellhousing, the CPS mounting holes will be roughly 0.15" higher than a standard B230F bracket.
- To mount the knock sensor, and to add a turbo support bracket (if not already done), you'll need to drill and tap a few holes.
-- Knock: M8 thread, ~0.86" hole depth, spot faced
-- Turbo support bracket (left&right pads under #3 cyl): M8 thread, ~0.85" hole depth
VSS - Vehicle Speed Sensor
LH2.4 needs a VSS signal to properly control idle speed. You can swap rear axles and clusters/dashes (?), or use a single fixed idle screw adjustment, or convert from a K-Jet cruise control speedometer pickup to VSS - see http://forums.turbobricks.com/showthread.php?t=342812
For pre K-Jet carburated cars, you'll need to figure out fuel pumps, a return fuel line, and maybe a different gas tank (I don't know if the early tanks included a swirl pot section).
Final engine bay picture:
If you have questions, please start a new thread to avoid polluting this one. If you have corrections, PM me and I'll edit this post.
-Bob
Parts:
-Bob
