- Dec 25, 2002
- mont, AL
This is a continuation of the chevy rod discussion below, but it doesnt deal specifically with that, so I'm starting a new thread.
There was some debate as to wether or not longer rods would be a good thing, so I've been researching the topic on the net (for my own benifit, but i'll share what i've found so far).
Long rod pros:
Less rod angularity
Higher wrist pin location
Helps resist detonation
A lighter reciprocating assembly
Reduced piston rock
Better leverage on the crank for a longer time
Less ignition timing is required
Allow slightly more compression to be used before detonation is a problem
Less average and peak piston velocity
Peak piston velocity is later in the down stroke
Less intake runner volume is needed
Cons:
Closer Piston-to-valve clearances
Makes the engine run a little more cammie at low rpm
Reduces scavenging at low rpm
Short rod pros:
Increased scavenging effect at low rpm
Helps flow at low valve lifts (a benefit if the heads are ported with this in mind)
Slower piston speeds near BDC
Allows the intake valve to be open longer with less reversion
More piston-to-valve clearance
Can allow for a shorter deck height
and cons:
More rod angularity
Lower piston pin height (if the deck is not shorter)
Taller and heavier pistons are required (again, if the deck height is not reduced)
More ignition timing is required for peak power
Things that I gleaned that are of direct interest for those of us that are boost-assisted:
Ignition timing.. less advance is needed with longer rods, which reduces the chances of detonation(well, detonation brought about by aggressive timing). Another thing of direct interest is longer rods don't move as fast and thus lower the reciprocating load placed on the rod, which is supposedly the leading cause of rod failure..
thoughts, comments, ideas?
Long rod pros:
Less rod angularity
Reduced piston rock
Cons:
Short rod pros:
and cons:
More rod angularity
