Inc3pt
- Mar 21, 2004
Hey all,
Having a bit of an issue with M46 overdrive. At first it will engage and then drop out after a few seconds, (the light turns back off, etc). After trying to engage it several times, it stopped wanting to engage at all (the light wouldn't even turn on). Because the light wasn't turning on even for a moment, I started to guess it had to do with the relay.
The next time I drove it, it seemed like it was ready to try again, and it would go in, then drop out again after a few seconds. The next time I tried holding the momentary switch for ~30 seconds just to see what would happen. Sure enough it stayed for the rest of the drive.
It started acting up again this morning when not even holding the switch for a while helped. I pulled over the freeway and changed the relay out with another one I had. I tested it with the car off, worked "normally".
Once I got on the road, it sort of acted the same way. Then, when it wouldn't want to do anything at all when pressing the button, I tried wiggling the gear shift to see if maybe the fourth gear switch was acting up. Immediately after, the OD came on and stayed on the rest of the trip.
So, this leaves me with two questions:
1) Do the symptoms I describe sound like its relay/fourth gear switch related? Or could it still be mechanical (ie: solenoid, tranny fluid low, etc)?
2) Does anybody have the pinout for the relay? I would like to take the fourth gear switch out of the equation. I'm assuming the switch just grounds a pin when the car is in fourth, so I could just ground it at the relay if I know what pin it is.
Thanks!
Thanks!
