M46 swapped regina 740 need Od wiring help
okoye
Connecticut
Hi manual swapped my 91 regina volvo 740 and need help wiring the overdrive or finding a harness that plugs into the 4 prong connector.
I have the yellow connector hooked up, I need assistance with the rest of the wires. reverse, overdrive etc.
Wiring should be the same as with a Bosch car swap, no?
I thought it was just the flywheel that was troublesome with regina swaps
I just need pictures yes the overdrive wiring is the same 740 and 940 I just need pictures of what goes where
Maybe one of these will help?
Taken from here: https://www.carknowledge.info/volvo-740-1990-wiring-diagrams-overdrive-controls/
Power, ground, button signal, 4th gear signal, and output for the overdrive relay.
Jump the neutral wiring together for the starter, and then run the reverse wiring to the new trans from the former neutral safety switch.
Easy peasy
