that's fineVery odd.
MaxxECU online docs say to hook up Hall type Home sensor to +5v sensor, and sensor ground.
I sent an email to MaxxECU, and they responded and said, hook to +5v and VR gnd. Which, seems weird.
It turns out, my OEM hall cam sensor is 12v, so I'm just going to connect to switched 12v and chassis ground, and provide the signal to the maxxecu home input.
I have Bosch double amp in Volvo B4204 (Four cylinder whiteblock) but that is Waste Spark application. But normal Volvo LH2.4 amp will be ok. Then another project is Chevy TPI V8 with Maxxecu's own small amplifier, but it will take some time until the sparks start to fly.Anyone use maxx with distributor ignition? What did you use for an amplifier/powerstage? The one in the maxx site looks slick and small. I know wasted or sequential is better, but maintenance aside, is a distributor really that bad?
I live in a state where keeping a stock looking ignition system and hiding a mini in an empty LH box would be smart for...... esthetics
Could you explain this more?another project is Chevy TPI V8 with Maxxecu's own small amplifier, but it will take some time until the sparks start to fly.
The stock ignition amplifier is nothing more than a single or pair of FETs, think of it like a very fast solid state relay as they are the same design. These parts rarely go bad unless they are overheated.Could you explain this more?
I have used 2 amplifiers so far, they both had some issue. I have very nice 8.5mm wire, good plugs, and Bose blue coil so I think very solidly the amplifier is my weak point.
1. MSD 6al CDI box plugged into my LH2.2, it works good under 50%-100% throttle but I always got some misfire under light cruse throttle.
2. The stock Boch amplifier, had some issues with spark blowout if 14+ lbs of boost.
I am hoping the Maxxecu amplifier will perform better, plus its quite small and looks pretty.
If you got spark blowout at boost the sparkplug gap might be too much.Could you explain this more?
Race unit, and convert it to drive by wire.@WillettRun? Nice job on Randy Pobst's car. I wish my former racecar cold started like that. New owner of car is looking to put a B6304 in it, starting NA, but eventually turbo, with a 8HP70. It will be for endurance racing. Any suggestion on which MaxxECU to use?
Its tolerant. just don't blow the diode!Does MaxxECU support direct 12volt input signals, such as "AC Switch On" and "AC Compressor On"?
The help docs show a +12V signal being used with an Analog "AIN x (0-5V)" pin. Is this correct? What about connecting a +12volt signal to a Digital DIN pin?
What are the high/low voltage thresholds used for DIN pins? and for AIN pins when configured as digital?
1/10/25 Edit: I guess I need to answer my own questions. This is not an official MaxxECU answer - use at your own risk. Maybe @WillettRun? can provide an official confirmation?
I ran some benchtop voltage-current curve traces of a few inputs on a MaxxECU Mini (HW rev 11) and, based on the knee at 5 volts in the curves, I believe that both the DINx digital inputs and AINx analog inputs are 12volt tolerant. The knee implies that the input is properly diode-clamped to a max of 5volts on the PCB.
I ran these measurements with the DINx internal pullup resistor disabled. When enabled, the pullup draws a max of 2.0mA when the input is grounded.
For the DINx digital input thresholds, there's a ~1volt hysteresis - the measured Vin,low-to-high threshold is 3.92volts and the Vin,high-to-low threshold is 3.03volts. I think the DINx inputs are implemented using continuous ADC sampling within the box, and that the hysteresis is done in firmware.
For the AINx analog input thresholds, when in Digital Input mode, there's no hysteresis and the high/low threshold is at 3.0volts. In analog mode, the ADC range is 0v to 5v (inputs larger than 5v are reported as ADC=5.00v).
Yep, those are them. they are useful if you do not wish or require defining your own data.DING DING, the CAN "data transmission" menu is what I'd overlooked a dozen times.
THANKS!!!!
I recommend an AEMX wideband, and using CAN to communicate the lambda signal, so you dont eat up an analog input (they are precious on the mini)Question about the Mini, If i'm running an AEM UEGO wideband, can i use the output on that to communicate that info directly to the Mini?
I just installed an AEMX CAN wideband, and it's working just fine as a 2nd WB input to my Race. It's a bit of a struggle to get the non lambda fields understood (eg, status bits, and for Maxx to correctly use them for "2nd wideband " status, but the lambda CAN fields work as expected.I recommend an AEMX wideband, and using CAN to communicate the lambda signal, so you dont eat up an analog input (they are precious on the mini)
Unfortunately, those advanced status bits are not supported. Perhaps one day we will get scripting.I just installed an AEMX CAN wideband, and it's working just fine as a 2nd WB input to my Race. It's a bit of a struggle to get the non lambda fields understood (eg, status bits, and for Maxx to correctly use them for "2nd wideband " status, but the lambda CAN fields work as expected.
That'd be awesome (scripting of some sort). I'm just going to CAN the status bits over to my AiM logger, and create warnings and popups there. Not ideal, but better than nothing. (I don't use Mdash in the car.)Unfortunately, those advanced status bits are not supported. Perhaps one day we will get scripting.
