dbarton
Dejected by Volvo Corp.
- Nov 17, 2002
- Prosper, TX
I bought a new Mechman 140A alternator for my 242. This originated from ILLINTENT and BADVLVO's charging system thread here: http://forums.turbobricks.com/showthread.php?t=213215
The reason I bought this is three-fold.
1. I'm using a lot of juice in my 242 and the 100A Bosch unit is barely hanging on.
2. The Bosch unit really doesn't do well at idle, especially when running AC with big pusher and puller fans. The puller fan I'm currently using is at the bottom of this page: http://www.davebarton.com/ElectricCoolingFans.html. It pulls close to 40A at full speed.
3. The Bosch unit suffers pretty bad when it gets heat soaked and the difference between cold and hot voltage under heavy loads can be from 14v to 12v. Yup, a full 2 volt drop.
Illintent has assured me that the large case 140A unit I bought will have excellent output at idle and will cool lots better than the Bosch unit.
So let's see....
Here's the Mechman unit next to my Bosch 100A unit. Illintent provided some spacers to make it simple to mount it in my normal 240 lower-right spot.
I ended up using the stock adjuster bracket you'll see in later pics. But I flipped it over to compensate for the fatter mount point on the GM alt. Surprisingly, it fit pretty well.
Here ya go... installed.
Here you can see the back spacer.
And since there's no place on the case to attach a ground cable, I did it this way.
BELTS: The stock belts are 10x925 mm. This alt requires larger belts because it will not swing toward the motor as much as a Bosch. I used 10x965 mm belts and it was a perfect fit.
So let's see....
