Super1800GTR
- Nov 17, 2002
- Lanesville IN
I know there's lots of Megasquirting information on this site, but I haven't found anything b21ft (K-jet) specific. This will be a step-by-step guide on how to remove k-jet, & install megasquirt. It won't cover the assemby of ms (Lunixman is taking car of that for me). I'll try & include as many pictures as possible to illustrate the process. I hope this will show those who may be weary about doing a mod like this that it's not THAT hard. Seeing as
how I just started this swap last night, I'll update this thread as I go along & edit where I need to. Hold on... this may take some time.
Step1: PARTS
Sensors:
-Coolant Temperature Sensor (CTS) [MSD Ignition 2310] http://www.sdpc2000.com/
-Intake Air Temperature (IAT) [MSD Ignition 2320] http://www.sdpc2000.com/
-TechEdge Wide Band 02 sensor (WB02) www.wbo2.com
-02 VW GTI 1.8t front sensor www.1stvwparts.com
-Throttle Position Sensor (TPS) from a Volvo 850
Fuel:
-Injectors-> Either stock b230 turbo injectors or injectors from a Turbo Ford (brown tops)
-Fuel Pressure Regulator (FPR) from a late 80's turbo dodge (4bar) http://www.rockauto.com/catalog/catalog.php?carcode=1089312&parttype=6124 (1st one listed)
-B230 Fuel Rail
-Resistor pack for the injectors from a b230 turbo
-Walbro 255lph fuel pump
-Aeroquip Socketless 1/4in Fuel Line & Clamps http://www.racerpartswholesale.com/
Wiring & Connectors:
-My kit from Kenny (Lunix) came w/ a wiring harness . Depending on where you get your kit you may/may not have to source the harness.
-TPS connector & pigtail. Try to get this when you get the TPS.
-IAT & CTS. If you buy your sensors new they wont come w/ connectors or pigtails (unless you buy the MSD sensors. The connectors are available separatly for the other sensors. Check the MS website (under wiring & sensors) for part #'s & links. If you get your sensors from the junk yard go ahead & get the connector & a good length of wire (pigtail).
-Injectors. I think the connectors from any b230 Volvo will fit just about any injector you plan on using (could be wrong about this). The best source for this is probably the junkyard. Go ahead & grab as much of the FI harness as you can for good measure. **Make sure you get the metal clips that lock them into place**
-Fuel pump relay. 12v bat, switched 12v, fuel pump, ground. http://store.summitracing.com/defau...art=BGI-171035&autoview=sku&Ntk=KeywordSearch
-Male & female spade connectors
-Universal fuse block (5 fuses) & fuses.
-Spare wire (might be able to get by w/ hacking up your original harness but it's a good idea to have some extra).
-on/off toggle switch
Intake:
-Intake manifold from a b230 engine
-Throttle Body (TB) from a b230
-Cold side IC pipe & rubber elbow from a 740 turbo Volvo.
Gaskets and Seals:
-O-rings for b21ft fuel injectors www.fcpgroton.com
-O-rings for b230 fuel injectors www.fcpgroton.com
-Gasket for b230 TB to manifold www.fcpgroton.com
-Intake manifold gasket www.fcpgroton.com
Misc:
-Labtop for tuning-> Must have windows 98 or newer and a serial port.
-Volt meter
-Zip ties
-Soldering kit
-Shrink wrap, electrical tape
-Heat gun
-Wire crimper
-Basic hand tools
-Teflon tape
-Vac hoses. Save yourself the trouble & go ahead & replace these. You'll also need a little extra that goes to the ms ecu.
-Drill w/ drill bit for IAC
Rob
Step1: PARTS
Sensors:
Fuel:
-B230 Fuel Rail
Intake:
Gaskets and Seals:
Misc:
-Volt meter
-Zip ties
-Soldering kit
-Heat gun
-Wire crimper
-Basic hand tools
-Teflon tape
Rob
