sim
Mere Drab Mob
- Jun 12, 2010
- Port Moody, BC
I was lucky enough to find a low mile 1995 B230FD. I have it on a
stand with the head off, and I'm trying to determine the piston
deck height so that I can order a Cometic MLS head gasket of an
appropriate thickness for tight squish.
This motor will get a 15g turbo from an 850 and will have a 6500
RPM rev limit. I plan to keep the boost reasonable.
The motor is in great shape, all I'm planning to do is clean it
up, drill and tap an oil return, swap out the cam and the
intermediate shaft, and stick it into my 245.
I believe the correct tool to measure poke is a bridge that can
span a cylinder and hold a dial indicator. I'm not sure where I
can get one, it is the sort of thing usually only used by a
machine shop, and something a machine shop could fabricate with
no trouble.
Lacking the tool, but having a dial indicator and a magnetic
base, I set the thing up with a flat ruler across the cylinder so
that the piston would push the ruler up once it was above the
deck.
I'm not really convinced of the accuracy of this method, but it
was the best I could come up with to get an idea of the deck
height.
Here are the numbers I came up with:
Cylinder #1: 0.004"
Cylinder #2: 0.004-0.006"
Cylinder #3: 0.002"
Cylinder #4: 0.002-0.003"
This is the ruler set-up on #2 at full poke:
Any suggestions for a better approach to measuring the poke?
So, based on my measuring, a 0.030" gasket would be safe, and get
me into tight squish. I think the 0.027" would probably be okay
as well, but I'm not confident enough to order one.
Does this sound reasonable?
Also, any suggestions for prepping the block deck for the MLS
gasket? 600 then 1200 grit sandpaper wet?
Thanks for any pointers, I'm keen to get this thing into my
wagon.
no trouble.
deck.
height.
Cylinder #1: 0.004"
Cylinder #3: 0.002"
wagon.
