edgar333
- Apr 25, 2012
- Santa Paula
It went looking for oil..! grrrrrrrr
i gotta pull the head on this one right?
Vanilla milkshake.
The queen of all milkshakes.
Ouch..its not that bad is it.. is there anything different on these motors than any other motor ,as far as a head gasket job?
get the head HYDROTESTED when you yank it...cheap insurance against having
to do the job all over again...
*BEFORE* you yank everything, PRESSURE TEST THE COOLING SYSTEM to make
sure it IS coming from the head...
cylinder head on redblock is NOT a big deal to swop out the gasket....work w/care -
clean everything to within an inch of it's life...make sure head is FLAT and install a
NEW THERMOSTAT when you do the job....good time to do HEATER HOSES on
the back of the block (EZ access w/head off)..just sayin....
and:
- clean out the cooling system when the head is back on, don't forget to open the heater as well.
- change the oil + filter asap. Water and anti-freeze are not ideal lubricants...
I once replaced a cracked head on a volvo 340 , the sump was full of this mayonaise!
I got the job done just fine but the engine was never the same, the crispness had gone. I guess the rings and bores did not like that mayonaise...
any one have torque specs on hand?
I HATE Mayo
