Chuck W
- Apr 29, 2008
- Indpls, IN
I'm looking to see if anyone has any better wiring diagrams than the Greenbook one I've got access to.
I'm working on the '80 264 GLE (now a B21FT/MS car) and I'm trying to get the oil pressure gauge hooked up. The engine is from the '85 244GLT I had. In the process of prepping the engine for the '80, I redid the harness from Alt/oil pressure sender to the 8-socket connector that's on the firewall, right at the center.
On the '85, 3 wires came to this connector from the lower pass side of the engine.
Red- Alternator warning light
Black - Oil Pressure warn light
Green - Oil pressure gauge
The first two jive with the '80 harness, but the green one does not, as none of the earlier (75-80) cars had an oil pressure gauge standard.
The wire is in the #5 or #6 socket on the connector (not in front of the car at the moment), but I lose it when it comes into the cabin as part of the harness. I've looked through the wiring diagrams, and the Greenbook and nothing is called out for that spot.
Just looking to see if anyone has any more info before I start chopping up wires.
