I've been around for a bit and have been through my share of Swedish metal. Mostly as cheap daily drivers or potential projects that tend to find homes elsewhere prior to completion. After going through a small sampling of 7/9 series and a couple S70, it was time to find a 242 for a longer term project. Something more than just rack up some miles and do some routine maintenance. I've learned through owning 70 something vehicles that I cant leave anything alone, and projects tend to spiral out of control for me.
Knowing this, and myself well enough, I decided to seek out a solid 242, with my main priority being mostly rust free and straight. I was able to locate a good candidate on Facebook a couple hours away.
Its a 1982 242 DL, B21 and BW55. Its been off the road for about 12 years and has changed hands a couple times since. The interior was partially disassembled and the Kjet system has had some pieces removed and seems to be mostly gummed up from sitting. The pans are going to need some attention as well as the section that the front seats mount to that crosses the tunnel. At least the quarters and trunk area are solid.
I picked up this 89 245 from Voluparts in Atlanta for a floor pan section donor for the seat riser and what ever else it may have left.
The goal for the 242 at this time is to get the Kjet system removed, and get the car up and running on Microsquirt as well as get the floors solid once again.
