760 No low beams or tail lights/brakelights
urbanwheeler
Santa Cruz, CA
So I have ruled out all but the wiring, and the fact that the bulb fail electronic "module" is missing. The bulbs are good and there, but I cant get the brake lights (other than the 3rd one) to work, only 2 of the tail lights works, and there are no low beams (bulbs are good though).
If the red bulb fail warning module is missing, would it cause the lights to not work?
I believe any red one will work, but not the black one. Count the pins on the connector, find one in the JY with the same number of pins.
Technically it can be bypassed. But you'd need a buttload of jumper wires. Faaaar easier to replace it.
I'll see if I can get one from the PnP, if not, I'm bypassing it, since the fuse box is already apart to repair other damage (the high beam relay plug caught fire before I owned it).
Just get one at PnP... they fail often.
The high beam plug didn't catch fire.. it just melted. :) Damn relay gets hot (i recommend rewiring lights to a relay directly off the battery in engine compart).
