t8fanning
8v are still cool, right?
- Oct 10, 2010
- Vancouver, WA
I don't have any experience either. Just makes sense that if it was working fine, no need to replace them. Plus it's extra money and time.
No reason to throw away good bearings with nominal time on them.
Good to know the rings were easy to get. I'm interested to see what the MS reports back.
Oh this is still a new-ish build. I forgot about that. Carry on!
Awesome project!
I followed your example and did the Walbro 450 swap as you have pictured, but I cannot for the life of me get the assembly back in. Is there some magic trick or special procedure you can reveal? After knocking off the sock into the tank the 3rd time, I quit
Not quite sure what you're asking. The sock can only go on the pump one way and is wider than the hole. I'm putting the sock in first, but the wider lower body of the Walbro and the float together are too wide for the hole. The sock pops off when trying to take it back out maybe because I am not folding it to get it out like I do putting it in.How did you angle the sock?
It didn't fall out, it cracked like an eggshell. Crap!......then kinda pop the float past the hole and hope it doesn't fall out.
Man that sucks about rings! I remember during the build if they recommended any different rings too. Hope you hit that whp goal!
