Timmermans
- Nov 10, 2017
My AMM wires and wires from the Buchka EZK to the ignition module/2x2 Bosch, all run through the same grommet through the firewall, could this be an issue? Google Gemini suggest so:
That makes things perfectly clear! Knowing you are running the Buchka Wasted Spark board inside the EZ116K (EZK) box completely changes the wiring geography and confirms exactly why you're getting EMI noise on your Air Mass Meter (AMM) lines.
Because it's a 240, your EZK box is mounted in the passenger-side footwell right above the carpet—literally inches away from the LH 2.4 engine ECU and the main engine harness entry grommet.
When you run the new logic wires from the Buchka board out to the engine bay, you need a highly intentional shielding strategy. Here is the exact game plan for which wires to isolate, how to group them, and how to build the new harness.
To isolate them effectively, follow this structural layout:
[Inside Cabin]<br>Buchka Board Outputs (1-4 and 2-3) <br> │<br> └─► Twist these two 5V logic wires together (roughly 1 twist every 3 cm).<br> └─► Wrap them in a shielded braided sleeve or use a pre-shielded 2-conductor wire.<br> └─► CRUCIAL: Ground the shield drain wire ONLY at the EZK box chassis.<br> │<br>[Through Firewall (Separate Driver-Side Grommet)]<br> │<br>[Engine Bay]<br> ├─► J720T Ignitor (Keep it mounted away from the passenger-side harness).<br> └─► J720T Pin 4 (Ground) ──► Short, thick wire directly to the Engine Block/Intake.<br>
I have a 1992 volvo 240 with a B230FT and a Buchka wasted spark setup with the Bosch 2x2 coil and a J720T ignition module. The other option Gemini suggested was gapping the plugs to 0.6mm because they are brand new, to reduce interference.
1. The Wires to Pull and Isolate
You want to remove four critical wires from your main passenger-side engine harness bundle and group them into their own distinct path:The Low-Voltage Logic Signals (Inside the Cabin to Ignitor)
- EZK "1-4" Output → J720T Pin 2 (Logic Trigger 1)
- EZK "2-3" Output → J720T Pin 5 (Logic Trigger 2)
Note on the Buchka board: On certain production runs of the black Buchka boards, the "1-4" and "2-3" pads were programmed backward. If your car runs fine but stutters under load, the order is correct—just make sure these two signal lines are kept clean.
CFloMoTo
The High-Current Switching Signals (Ignitor to Coil in Engine Bay)
- J720T Pin 1 → Coil Pack Negative A (Cylinders 1 & 4)
- J720T Pin 3 → Coil Pack Negative B (Cylinders 2 & 3)
2. How to Bundle and Shield Them
The low-voltage signals coming straight off the Buchka board are extremely vulnerable to picking up stray electrical noise. At the same time, the wires going from the J720T ignitor to the coil pack carry high-current spikes that create noise.To isolate them effectively, follow this structural layout:
The Shielding & Grounding Rules:
- Twist the Logic Triggers: Twist the 5V logic signal wires coming out of the EZK box tightly around each other. Twisting helps cancel out induced electromagnetic fields.
- Use a Drain Shield: If possible, route the logic wires through a grounded metallic braided sleeve. Only ground the shield at one end (the EZK box case ground). If you ground both ends, you create a ground loop antenna, which defeats the purpose.
- Isolate the Coils' Ground: Make sure Pin 4 of your J720T module is grounded directly to the engine block or intake manifold ground via a short, heavy-gauge wire (2.5mm2 / 14 AWG). Do not route this ground back into the cabin or tie it to the AMM/ECU sensor grounds.
3. Physical Routing Strategy
Since the EZK sits in the passenger footwell, drilling a hole on the driver's side might mean running a long span of wire across the inside of the dashboard. If that is too difficult, you can still use the passenger side of the firewall, but you must use physical distance:- Option A (Best Isolation): Route the twisted, shielded Buchka logic wires across the inside of the dash and out a new grommet on the driver's side firewall. Mount the J720T ignitor and the 2x2 coil pack on the driver's side inner wing/fender. This completely maps the ignition system away from the AMM harness.
- Option B (Passenger Side Bulkhead): If you must go out the passenger side, punch a new hole at least 15–20 cm (6–8 inches) away from the massive factory engine harness grommet. Run the wires inside heavy conduit directly to the front of the engine bay, keeping them clear of the AMM's physical location and its low-voltage wiring.
