Oil Filter Question
Turbo Jake
CT
Have a 88 240 with a 15g and a 3 inch dp. Any shorter oil filters available? The napa barely, just barely threads on. Many thanks.
Should be plenty of clearance no? IIRC, only the motor mount is near the filter? (2.5" DP in photo)
IF you are considering a remote filter mount---and it is a joy once its done and so nice to feed the tubo nice fresh from the cooler oil, then look at this:
Perma-Cool Remote Oil Filter Brackets 1791
Perma-Cool 1791 - Perma-Cool Remote Oil Filter Brackets
Click to Enlarge Image
$28.35
+Compare
Oil Filter Mount, Single Filter, 1/2 in. NPT Inlet/Outlet, 3/4 in.-16 Thread Filter, Each
2 Inlets and 2 outlets...
Combine that with spin on outlet where the filter went---out to cooler, then from cooler to the filter head IN---> then one of the OUT----> goes back to old filter block off deal and the OTHER OUT---> goes to turbo IN.. The remaining port use for oil pressure and oil temp senders via a T
