n xntrx volvo
Newbie
- Dec 5, 2003
- corinth, ms / los angeles
Forward
Volvo is a well diversified Company. Aside from the manufacture of Heavy trucks, they are also well known in the Marine world for their boat motors. Some Engines are re-badged Versions of Chevy and Ford Engines, but some are based on Volvos own engines. Due to boat motors being ran for several hours at high rpm's, many items in these motors have been upgraded internally. Most have also been mixed with the best of the volvo parts bin, and/or had penta specific parts added in the quest to add aditional hp without turbocharging (marine folks have a harder time finding good gas sometimes). I have compiled a list and info of models that are of interest to those on this site.
Happy hunting,
-Aaron
Happy hunting,
-Aaron
General
volvo factory info/ sales lit
Aq125a
-2.1L
-80MM stroke
-8v 1000160 head
-"A" cam,
Aq125b+
-2.3L
-80MM stroke
-8v 1000531 head
-"A" cam,
-CR 9.8:1
-120hp
Aq131 / aka 230, 275
-2.3L
-80MM stroke
-8v 1000531 head
-Single Carb
-"A" cam
-120hp
- cast crankshaft
-529.1lbs
Aq145
-2.3
-80mm stroke
-8v 1000531 head
-Dual Carb
-"V" cam
-All Square Tooth Belt
-CR 9.7:1,
-138hp
Aq151 = aka 250
-2.49l, or 151ci
-86MM stroke
-Forged crankshaft
-8v 1000531 head
-Dual Carb
-"V" cam
-CR 9.7:1. comp press 142-170psi
-Cast V pistons
-All Square Tooth T-Belt
-146hp
-551.2 lbs
-max speed 5500 rpm
Aq171/ aka 251a(dohc)
-2.49L, 151.9ci
-86MM stroke
-16V Head
-Dual Carb
-"PZ" cam
-CR 9.7:1
-Cast V pistons
- Forged Crankshaft
-All Round Tooth T-Belt
-167hp
-637.15lbs
Induction
All are carb, generally Solex. This is a good way to id the high performance motors. Single are budget (for a marine motor), dual are high performance.
Blocks
Aq125, Aq140, Aq145 = b2x block
Aq131, Aq151, Aq171, Aq251 (dohc) = b230 block
Super Marine block which is very similar to the R block. It can be bored up to 99mm successfully.
No pentas came w/ squirters, they have the bolts/are machined for them in late ones though. They can be easily added to these motors.
Stoker/ crank info
The aq151 and aq171 had a 86mm stoke crank. This compares to normal Volvo Auto 80mm, giving them a 2.5 liter displacement. These crankshaft are direct replacements for b230's of the same era.
The letters after the Penta number are important. Stay away from the A. It had small mains and was based on the 9mm rods. Early Penta motors, just like early B230s, had less desirable bearings and bearing location, and rods. Blocks produced before 1988 used small mains and 9mm rods, 1988+ = 63mm mains and big rods.
Some penta cranks are forged (cast units are noted below). The forged crankshaft will have a thick parting line on the counter weights.
Breakdown by model
- Small
AQ131A, AQ131B (cast)
AQ151A, AQ151B
AQ171A, AQ171B
-Large
AQ131C, AQ131D (cast)
AQ151C, AQ151D
AQ171C, AQ171D
sp 230 (all) (cast)
sp 250 (all)
sp 251 DOHC (all)
Rod / Piston interchange
the AQ151 and AQ171 use the same 152MM long conn rods as the B230 engine, and use a 3MM shorter compression height (wrist pin to piston crown) to compensate for the longer stroke.
<table frame="hsides" rules="all" width="360"> <thead> <tr style="height: 2cm;"> <th title="Piston dimensions (mm) / Piston pin dimensions (mm)" colspan="2" align="center">
</th> <th title="Mounting of piston rings" align="center">
</th> <th title="Nominal diameter of cylinder" align="center">
</th> <th title="Piston article number" align="center">
</th></tr></thead> <tbody> <tr> <td align="center"> <table> <tbody> <tr> <td title="Compression height">Compression
Height
</td> <td align="right">36,7</td></tr> <tr> <td title="Combustion chamber depth">Combustion Chamber Depth
</td> <td align="right">3,2</td></tr> <tr> <td title="Distance between bosses">Distance Between Bosses
</td> <td align="right">25</td></tr> <tr> <td title="Total length">Total Length
</td> <td align="right">61,7</td></tr> <tr> <td colspan="2">
</td></tr></tbody></table></td> <td align="center">Total Length
Pin
23
x
65</td> <td align="center"> <table> <tbody> <tr> <td title="Ring type: Rectangular ring">R</td> <td title="Height of ring">1,75</td> <td>Cr </td></tr> <tr> <td title="Ring type: Taper-faced Napier ring">NM</td> <td title="Height of ring">1,75</td> <td>
</td></tr> <tr> <td title="Ring type: Coil spring loaded slotted oil control ring">SSF</td> <td title="Height of ring">3,5</td> <td>
</td></tr></tbody></table></td> <td title="Nominal diameter of cylinder" align="center">96,01</td> <td align="center">037 03 00
96 V 18</td></tr></tbody></table>
Cams
the V-cam has 11.37 max lift inlet and outlet and has an overlap of apr. 12 degree. lobe separation (108.5)
For more 8v camshaft info click here
Aq171 pz cams, the lobes on the PZ cams are 0.7mm taller from base to peak then the stock cams and about 0.5mm wider across. For a PZ review click here. PZ's are a drop in for 16v cars also.
Cylinder Heads
info
<table border="0" width="740"> <tbody><tr><td class="sheetText" width="610">Cylinder heads for petrol engines consists of:
Cylinder head, intake and exhaust valves, valve springs, washers and lock. For B21, B23, B230 and B250 engines camshaft is also included.
</td> </tr> <tr> <td width="610">
<table border="1" bordercolor="#8e95db" cellpadding="2" cellspacing="0" width="100%"> <tbody><tr> <td class="sheetTH" align="left" valign="top" width="60">Pos no.</td> <td class="sheetTH" align="left" valign="top" width="80">Part no.</td> <td class="sheetTH" align="left" valign="top">Engines/Drives</td> <td class="sheetTH" align="left" valign="top">Spare part no.</td> </tr> <tr> <td class="sheetTD1" align="left" valign="top">90.1</td> <td class="sheetTD1" align="left" valign="top">3803012</td> <td class="sheetTD1" align="left" valign="top">AQ115A, AQ130, BB115A, MB20A</td> <td class="sheetTD1" align="left" valign="top">831656</td></tr> <tr> <td class="sheetTD2" align="left" valign="top">90.1</td> <td class="sheetTD2" align="left" valign="top">3803018
1) </td> <td class="sheetTD2" align="left" valign="top">AQ120B, AQ125A</td> <td class="sheetTD2" align="left" valign="top">463630</td></tr> <tr> <td class="sheetTD1" align="left" valign="top">90.1</td> <td class="sheetTD1" align="left" valign="top">3803025
2) </td> <td class="sheetTD1" align="left" valign="top">AQ140A, BB140A</td> <td class="sheetTD1" align="left" valign="top">463630</td></tr> <tr> <td class="sheetTD2" align="left" valign="top">90.1</td> <td class="sheetTD2" align="left" valign="top">3803226
3) </td> <td class="sheetTD2" align="left" valign="top">AQ145A, BB145A</td> <td class="sheetTD2" align="left" valign="top">857532</td></tr> <tr> <td class="sheetTD1" align="left" valign="top">90.1</td> <td class="sheetTD1" align="left" valign="top">3803166
3) </td> <td class="sheetTD1" align="left" valign="top">AQ145B</td> <td class="sheetTD1" align="left" valign="top">1346408</td></tr> <tr> <td class="sheetTD2" align="left" valign="top">90.1</td> <td class="sheetTD2" align="left" valign="top">3803167
4) </td> <td class="sheetTD2" align="left" valign="top">230/SP, AQ125B, AQ131</td> <td class="sheetTD2" align="left" valign="top">1346408</td></tr> <tr> <td class="sheetTD1" align="left" valign="top">90.1</td> <td class="sheetTD1" align="left" valign="top">3803168
5) </td> <td class="sheetTD1" align="left" valign="top">250/SP, AQ151</td> <td class="sheetTD1" align="left" valign="top">1346408</td></tr> <tr> <td class="sheetTD2" align="left" valign="top">90.1</td> <td class="sheetTD2" align="left" valign="top">3803201
6) </td> <td class="sheetTD2" align="left" valign="top">AQ171 DOHC</td> <td class="sheetTD2" align="left" valign="top">856528</td></tr> <tr> <td class="sheetTD1" align="left" valign="top">90.1</td> <td class="sheetTD1" align="left" valign="top">3803201</td> <td class="sheetTD1" align="left" valign="top">251DOHC</td> <td class="sheetTD1" align="left" valign="top">856097</td></tr> </tbody></table>
1)
A camshaft.
2)
D camshaft.
3)
K camshaft.
4)
A camshaft.
5)
V camshaft.
6)
Piston kit 876236, 4 pcs. are required.
</td> </tr> <tr> <td class="sheetText" width="610">
</td></tr></tbody> </table>
1)
2)
3)
4)
5)
6)
Alternator
B23 based blocks use these mounts Penta's mount low and on the drivers side. 50 amp. These mounts can be used on car red blocks, using stock holes. Most i've seen, are GM style alts, w/12 and 6 clocking. The B230 based ones have a small alternator mount built into the motor mount bracket.
Condition advisory
While these engines use a fresh water cooling system (a seperate cooling system from the sea cooling system) the salt water/ sea water still exits through the exhaust manifold. this causes corrosion on the #4 ex port, which is why these engines have round, sleeved exhaust ports there.
Identification
the first entry (shown as 250b on the example) is the engine designationThe Pentas use a small ID plate on the starter section of the block
the second entry (next to the last) is the product number
next line, (first ten digits) Serial number
the last 5, basic engine serial number
there also is the product designation, on the block. Its located right under the head, drivers (in a car) side.
Date code on the block is the same as auto units. just to the rear and lower than the oil filter. its a XXXXXX. the first two are the year of manufacture, ie 93 = 1993 etc. This plate will be obscured by the oil cooler on the dual carb models.
That oil cooler (click here for pic) will be a tip if loking for a 2.5l short block. It was only on dual carb models. The oil filter bolt will be extra long for this if its been removed. All 2.5l blocks are still stamped "b230" on the passenger (in a car) side.
The easy visual differences between the b23 and b230 based engines:
#1 The harmonic damper on the front. It will be a solid unit on b23/b21 engines. On b230 based engines it will be a 2 pc unit, connected by a rubber insulator inside.
#2 The valve cover: on b23/b21 based units it will be flat across the back. On b230 based units, it will have a half circle for the dizzy on autos.
*Note*, some late b23 based ones do have the late style valve cover, use #1 whenever possible.
Fyi, the late engines are manufactured with two different product designations. During the 1989 Volvo Penta Begain designating engines based on their cylinder diplacement according to the ISO norm 8665. The designation is listed above in the engine descriptions. ie, a aq171 is a 251 from 1989 on. Since these are the models you'll most likely be interested in, use these in your search criteria.
Parts specs and #'s
parts catalog*Warning* Volvo Penta Parts are expensive. These engines are heavily prized in both the automotive and marine world. You'll also find that anything in the marine world is extremely over-priced.
aq171 parts
belt =
-#855506-2
-146 teeth
-timming marks on belt
tensioner
-#855507-0
-non-spring loaded, vw style
cam (in) =
-#855777-9
cam (ex) =
-#85778-7
shimed lifters = 1317798-5
aq171a crank =
-855482-6
-main bearing dia, 55mm
aq171c crank
-3514121-7
-main bearing dia
piston kit std
-876033-2
-height pin to top, 36.7mm
-overall height, 61.7mm
-all light alloy
piston kit .030
-876034-0
piston kit .060
-876035-7
block dizzy plug
-1336764-4
timming pointer for aux shaft (aq171 specific)
-834485-5
tensioner bolt
-959245-2
tensioner spacers/washers
-955895-8 & 855795-1
drivers side alt mount
-831763-8
valve (in)
-34.5mm
valve (ex)
-31.5mm
spark plug
-.276" gap
ignition
-rex
