Yep I'll do a 2.5L 16v NA setup eventually, have most of the parts, mostly just need the time/space to do the rebuild. Going to use an early low friction B230 block for the build.
So I've been chipping away at my list of stuff to do on the car. Since my last post I changed my springs from 500lb/in front to 300lb/in, and 250lb/in to 200lb/in rear springs. For the front I used Eibach 1000.2530.0300 barrel springs which were a few dollars more than the standard 2.5" coilover springs, but provide 174mm of travel until block height so I can finally use the full travel of the Koni front struts even with a bit of preload.
The ride quality is a lot better now, wish I would have done this 10 years ago. I also put on an IPD 25mm rear ARB because the car was a bit more understeered at the limit than I wanted. Once I revalve the rear dampers this thing is going to be pretty sweet.
I sanded and painted the factory tow hitch I've had kicking around forever, and finally installed it on the car.
Probably biggest improvement on the list of things was to install the rest of the air conditioning setup that I pulled many moons ago from a junkyard '93 240 car. I had already installed the whole heater core/blower/evaporator thing like 10 years ago, but finally got around to the rest. Had to switch over to the 90+ power steering pump at the same time, so I did that too. Cleaned up all the brackets and lines:
Super annoying that you can no longer embed photos from Google Photos, hopefully these links work at least.
Tap to view!
photos.app.goo.gl
Got everything connected and pulled it down to 500 microns to let it sit for a while before I filled with R134a:
Tap to view!
photos.app.goo.gl
Annoyingly, the terminals for the connector on the body side of the harness had completely disintegrated, even though the fan side looked good as new. Replaced both sides of the connection with a DTP connector:
Tap to view!
photos.app.goo.gl
Installed the condenser fan and used window isolation foam around the condenser before I reinstalled the slam panel:
Tap to view!
photos.app.goo.gl
Was getting around 13C in the vents with fan on full sitting in the garage when garage temp was about 32C. And of course the day I finished installing the system was the last day of summer, so I haven't actually turned it on while driving yet. Most annoying part of the installation was the replacement orifice tube. The original one came out no problem, but the generic replacement I got would absolutely not go back in. I ended up ordering a new one from FCP when I was ordering some other parts since it was only like $2, and that one ended up working. I measured all of them when I had them on the bench, and it was a tiny small difference, like 0.2mm difference on the oring, but apparently that is enough to make it impossible to install.
I used some rubber isolators I got from Amazon instead of paying $8 per for the genuine Volvo ones for the condenser fan, and they lasted all of 50 miles before one sheared completely off:
Tap to view!
photos.app.goo.gl
With the new suspension and trailer hitch and AC retrofit, I took the car in to work to corner weight it and do an alignment. Full tank of gas, without me in it:
Tap to view!
photos.app.goo.gl
With me in it:
Tap to view!
photos.app.goo.gl
49.9% diagonal so I think that's about as good as I can do
Front left caster was a bit low but didn't have a way to increase this without reducing camber, so I kept camber the same. Will see if I can fix this some time in the future:
Tap to view!
photos.app.goo.gl
Next up is to wet sand and polish the whole car, and continue fixing all the rattles and noises. I recently found out that the tailgate hinges have a decent amount of slop, so the whole thing is moving around and sounds awful when I go over potholes and trashy road surfaces, so I really need to fix that. The car is really coming along nicely though.
