n xntrx volvo
Newbie
- Dec 5, 2003
- corinth, ms / los angeles
yes i know many have spent lots of money and failed (via level 10)
yes i know there's other options
yes i know i'm asking for a let-down
yes i've rebuilt auto trannies for performance apps (all w/ guides though)
yes i've done research
yes i've got the rebuilding books
now that thats out of the way
goal:
make a aw handle 400hp drag launches
why:
i'm nuts. if it works, it'll clear a major hurdle for most volvo folks
questions:
common performance aw failures? (the 2-3 etc)
using a aw72 converter on a aw72? (2.3 amplification vs 1.8 is why)
diesel clutch pack details? (checked kiwi posts)
removing cushion plate on od drum?
conv amplification formula?
forged foward clutch hub part# 4466343, cant find model used, tranny or vehicle.
plans
aw70-71 bellhousing
aw70-71 tail housing
aw372 aka a44d tranny base (87-89 ram50/d-50, non-lock up, rated at 320lbs stock)
blue plate clutches (r577310 forward/ direct x14, r577320 low/ reverse x5, r577350 od brake x3)
aw71 valve body
spacers in servos instead of springs to raise the pressure
aw72 governor (higher rpm)
aw72 pump (wider)
aw71 gears
external filter set up
synthetic fliuds
reduce drum travel to below min to increase clutch # and decrease eng time
use thinner steels in packs to allow for extra discs
pump, rework the pressure port
weld up a deeper pan for improved consistancy
possible cryo treatments of any reported weeknesses
forward clutch, remove snap ring for extra clutch (as done on some stock)
notes:
no valve body mods planned. prefer to do through other means to reduce pressure on pump
long range project, no funds at this moment. should change shortly.
i'll most likely need to aquire most of an aw72 to go with the aw372 and aw71. will be comparing items as they are disassembled to find the best mix of parts.
not enough budget to get a conv built, plus that'd add more strain on the tranny.
upgrade to higher (numerical) gearing to reduce strain, and improve launch.
will be adding info to this post as needed. just getting it off the memo pads.
fyi:
aw = aisin warner, jap built borg warners
aw's were used by toyota, kia, volvo, suzuki, isuzu, mazda, dodge (mitsu built), and mistubishi (can provide more info to which if needed).
a aw372 is the same as a km148 found in monteros. its the same from the governor to bellhousing. it just happens to have a tranfer case hanging off the back (hmmmmmm 4wd.......)
a version of the aw372 was used in the 4 runner also (89-91 4cyl), called a a44d.
tag number for all is 03-72
general aw notes
stall speeds (engine / rpm)
b17a = 2300
b19a = 2100
b21a = 2200
b23a/e = 2400
b19e = 2500
b21e = 2550
b21f = 2100-2500
b21f mpg = 1800 (aw70)
b21f lh = 1980 (aw70)
b21ft = 2050-2500 (aw71)
b23f = 2200 (aw70)
b27 a/e/f & b28a = 2200 (aw70)
b28e/f = 2300-2400
b20 = 1950
b24 = 2200
Plower flow chart
gear selector position/gear/ clutch applied/ planetary gear used/ brake applied/ one way clutch applied/ engine braking
last, but not least:
goal:
why:
questions:
plans
aw70-71 bellhousing
aw71 valve body
aw72 pump (wider)
aw71 gears
synthetic fliuds
notes:
fyi:
general aw notes
b17a = 2300
b19a = 2100
b21a = 2200
b23a/e = 2400
b19e = 2500
b21e = 2550
b21f = 2100-2500
b23f = 2200 (aw70)
b28e/f = 2300-2400
b20 = 1950
b24 = 2200
Plower flow chart
