Rubber. I had seen some people have complaints with the poly and it’s not like this thing is ever gonna be a racecar.Did you go with rubber or poly bushings?
I messaged Sellholm about a set with some custom valving for my intended use and really the estimate wasn’t horrible. Might just save the pennies for that.There aren't a lot of shock choices because the shocks in the back of a wagon are their own setup. Bilsteins, Monroe/stock, or KYB were all I could find at the time. So we used the KYB rear shocks and they have been good.
I just did a suspension order with them. Payment took a few days to clear, but it's arriving today just 4 days after the order was completed.I messaged Sellholm about a set with some custom valving for my intended use and really the estimate wasn’t horrible. Might just save the pennies for that.
So I did none of this. Instead I halfass painted the set of stock wheels white in preparation for mounting tires tomorrow and set the base timing to about 14* instead of the 22* it was at, which brought the idle down quite a bit as well to about what it should be.Tonight's project is to drain/refill/flush the cooling system, put in a new thermostat and radiator hoses, plus probably getting started on the front suspension bushings if I'm feeling frosty.
Make sure you install the tie rods correctly. Even the factory screwed it up on some cars. The end with a small bend goes inboard and they're handed. Also, the left hand thread center link end goes on the left side of the car for concours correctness.So I test fit the gravel tires yesterday, and in doing so I kinda gave the front wheels a shake with it up in the air. Idk why I hadn't done that before now, but there's...significant play in the tie rods and center link rod, so I ordered up a kit for that from VP, hopefully it'll be here tomorrow or Saturday.
Well that's good to know.I just did a suspension order with them. Payment took a few days to clear, but it's arriving today just 4 days after the order was completed.
I can't recommend working with them enough.
It's significantly cheaper to get new suspension from Sellholm than getting something revalved through Bilstein USA, FYI.
Not a clue. I guess I can measure tonight. I'm hoping to get the front suspension done and steering stuff redone tonight if I don't fall over asleep when I get home.What is the wheel travel on an amazon, something over 6in?
Looking at the motion ratio's and shock stroke lengths, ~8" or more front and back look feasible. That's plenty of travel for rallyYou can download the greenbooks here. Section 7 has some dimensions but I don't see wheel travel. Shock length extended and compressed should be close although the shocks are inboard in front and in front of the springs in the rear so you may need to adjust the figures to get an accurate wheel travel number.
