n xntrx volvo
Newbie
- Dec 5, 2003
- corinth, ms / los angeles
found some solid lifters to replace the hyd units in the 16v.
the b230 uses a .35-.4mm cold, .4-.45 mm hot clearance. should i use these for the 16v also?
fyi, the lifter is CEP2131726, avail from napa for 8.50 ea, or 25 for 8 on ebay new. its pre 84 vw watercooled (think gti)
the meas i have;
volvo:
dia 35mm (1.378")
total hieght 26mm (1.024")
actual unloaded 19.101mm (.752")
greenbook unloaded .724" (18.4mm)
greenbook loaded .636" (16.15mm)
vw:
dia 35mm (1.378")
actual thickness (0 shims) .243" (6.17mm)
shim thicknesses 3-4.2mm (.118-.165")
looking at lash caps to make up the diffence. (btw valve dia = 7mm, .276")
which spec should i be looking to match, loaded correct?
is there an easy way to measue distance from valve tip to base circle?
aiming for right in the center of shims, 3.6mm (.142")
my thinking is .636 (16v compressed)-243 (vw, no shims) = 393" - .016" (clearence) = .377"- .142" (avg shim) = lash cap of 235" (5.97mm).
sound right?
havent messed around much with solid tappets, so i migt be way off.
-Aaron
the meas i have;
volvo:
dia 35mm (1.378")
vw:
dia 35mm (1.378")
sound right?
-Aaron
