- Sep 18, 2002
any other things you'd have done differently such as donor vehicle choice or use of aftemarket parts??
Not at this point. 96+ ford explorer is the donor of choice IMO.
I re-used the existing suspension pickup points- cut them off the D30 and welded them onto the 8.8.
In retrospect I wouldn't do it that way. Some four-link brackets from summit and some rod and rod ends would have been easier, stronger, and more tuneable.
I know that for a 700 series it isn't quite that easy since you don't have pickup points for upper trailing arms/torque rods like a 240.
But my suggestion is that you consider the possibility of being rid of the "subframe" and set up a more "conventional" 4 link during the process of converting the diff. Maybe it's too hard on a 700, but I would at least have that possibility in the back of my mind when planning the swap.
The rest of the stuff I don't feel like commenting on- turbobricks logic (or lackthereof) just sometimes cannot recieve reason.![]()
Something to consider no matter which rear axle you choose. If you have to narrow the rear axle, you can cut off the ends of a Volvo axle and weld them to the ends of your new axle. Then by just redrilling your axles, you can use stock Volvo rear disc brakes and calipers.
So, If you used these 8.8 housing ends from Moser to use 9" small bearing axle shafts, do you first have to cut the original housing ends off, weld on the new ends, then shorten the Explorer housing tubes before the taper at the correct length, and then weld the tubes back together? I guess what I'm wondering is what is the Explorer tube diameter at the center differential and the housing ends?
http://www.moserengineering.com/Pages/Housing-Ends/housingends.html
MOSER HOUSING ENDS
New forged, CNC machined housing ends are available separately or on any housing we sell. These housing ends accept stock bearings and seals, and are available for most popular applications. The 8.8? Ford ends accept the small 9? Ford style bearing, but still work with most 8.8? Ford brake set ups. The Chevrolet ends accept the large Ford style bearing, but still utilizes most Chevy drum and disc brake set-ups.
PART # DESCRIPTION PRICE
New Housing Ends (pair)
7400 8 3/4" Mopar & Dana 60 80 pair
7450 Symmetrical/Lamb 80 pair
7455 Symmetrical Ends for Double Row Ball Bearings 125 pair
7705 2005-Newer Mustang (Ford large bearing & non c-clip axles) 80 pair
7700 1979-2004 8.8" Mustang (uses 9" Ford small bearing & non c-clip axles) 80 pair
7750 Big Ford New Style/Torino 80 pair
7755 Small Bearing Ford 80 pair
7800 Big Ford--1/2" holes 80 pair
7838 Big Ford--3/8" holes 80 pair
7850 Olds/Pontiac - 1949-1964 80 pair
7900 Small Chevy Car (Ford large bearing & non c-clip axles) 80 pair
7905 C-Clip Chevy Car (stock type bearing & seal and c-clip axles) 85 pair
7950 Chevy Impala & Truck (Ford large bearing & non c-clip axles) 80 pair
7750DB Deep Bore Torino (bored for 45 mm bearing) 80 pair
7800DB Deep Bore Big Ford (bored for 45 mm bearing) 80 pair
7900DB Deep Bore Chevy Car (bored for 45 mm bearing) 80 pair
COPYRIGHT 2005 MOSERENGINEERING, INC
I was out at the yard today. I saw about 10 explorers, and countless other Fords with 8.8 rears. None of them were disk brake type unfortunately. None of the Explorers were new enough for disk brakes.. Rear axles are on sale this weekend. $39. I should have grabbed something. But it was snowy and muddy, so I wasn't super motivated to work on the ground.
there was one 1994 Eddie Bauer Explorer that I could not rotate the wheels opposite of each other by hand. Though, the cover did not have the "L" tag. Maybe it had a dealer or aftermarket added LSD? It had drum brakes but otherwise was the best looking candidate. I may go back for it tomorrow.
I saw a couple of trucks with 9" housings. But they all had the diffs removed. The 9" looked like it might be a challenge. The abundance of 8.8 parts has swayed my choice. I'll run the 8.8 I think.
Didya at least look at the Toyota PU 8" rears.
Then its simply turning the OD and drilling the flanges.
And you get nice 4 pinion LSDs.
What is it that you booys seem to not understand the strength of 4 pinion diffs vs those 2 pinion things found in most Amerikanskij axles?
Don't see the Landcruisers in the low rent yards Kevvie and I hang around in.John/Kevin.... Have you fellers looked at the diff assembly in the V-8 Landcruiser?
Many of them come from the factory with an electric operated maybe vacuum locker.
They all have big vented discs.
I've never seen one fail so with a bit of luck it will not be silly expen$ive in the yards.
Not so worried about their breakes since what we've done on the 2 so far is just chuck the axle up and turn the OD and the backside of the flange and leave a step for Volvo disc to center on and drill 5 easy holes.
EASY!!!!
The 9" Ford thing in my car..... one could figure $3-4000 yankee dollars to fit one. My rear axle uses an old mustang housing shortened with Volvo suspension pick-ups on it. It has an Aluminum center section (saves unsprung weight), 35 spline axles that I should have had gun-drilled for weight savings, disc brakes (Volvo 740 turbo front rotor and Porsche/Brembo C-4 calipers) and is now dandy. The 9" rear is one that you can pick and choose any variable you like right down to having a sheet metal housing made up for your car. All it takes is money.
Lesse, I stink Kevvie paid like 110 bucks for his, I got him a 4.3 ring and pinion for $10, and he traded a something to get a Stuprah 4 pinion LSD for cheap.
He has under 250 in it and he did the plug-weld (with BOTH shielded and gas MIG at the same time) while I was doing the turning on the lathe.
He did the bolt circles--and got it right after I slapped him around and made him check the first one and re-check the mill heads levelling.
I may occasionally forget things but I USUALLY know to check for errors.
So all told it is EASY.
Oh and we drilled for the use of the Sooper Bitchin M14 x 2.2" stud I like so much.
Any of you who are $erious about doing a real custom thing...
I will be happy to put you into touch with a fellow who builds them. He is not interested in time wasters though.
