I'm looking for help dialing in a no start situation with a 1993 945 and a Regina ignition. I've searched and am suffering from TMI and need help dialing this in. A lot of troubleshooting is for a Bosch, too many differing opinions on how and what order to test, too many willing parts hangers, and on and on...
I believe I have a bad coil or more specifically a bad amplifier. Car ran great until I decided to clean under the hood with a pressure washer but really I just killed something that was on it's way out. So, I've got no spark coming out of coil. I did replace crank sensor but only because wiring was in poor condition albeit with a cheapie to have it to me quickly. I do now have em2 on the fuel pump relay staying on while cranking. Does this confirm pulse signal from crank sensor is working? At the coil I have 12Vdc at 2 outer wires of 3 pin connector to power stage. Middle pin tested for a good ground. Other 2 pin plug, dunno what to check for on those. Also measured 3.5Vac~ at the power stage as well. Measured the pass through current to the coil from 1 of the 12V leads at the power stage. So, I still feel like I'm guessing but I'm thinking coil is bad or more likely the power stage. Actual coil bench tested properly - although I don't think that test is 100% but that also let me rule out bad contacts from amplifier to coil. Looks good there.
Ok, that's all I have. Looking forward to hearing back from everyone!
