everyhumanvovo
- May 4, 2009
Well, blower motor is squawking (though less than it was a year ago) and now sucking voltage (really worn?), so this needs to be done. Seeking recommendations in Eugene or as far as Portland area for best no hassle results. Also, is this a 6, 7, 8, 9 hour job and what is best estimate I can expect? I've heard a place in Vancouver does install a bit differently from the side or something, but also saw this place had mediocre, not so glowing reviews.
Also, I obtained new blower blades and the clips from IPD. IPD did not have Siemens fans, so have two Siemens made in Mexico and both are old new stock. Siemens was oem make if I remember right (started to plan for this a year ago). Do not recall, but I think what IPD had were less expensive make from China so opted to look for Siemens motor. Rather have replacement go for another quarter mill than 75,000.
I think I read the fan should be run a little before install. One of the two Siemens fans I have has a bent bracket that rings horizontally around motor - bent evenly along one side about 1/4" curled over about 1.5" in length - so not tweaked very much but still wondering how it happened - not sure if was dropped hard or what. It looks a little better than the other than the replacement which has a little surface corrosion on spindles. Suppose can test both before install. Or, if there is best option like a new stock Siemens that would cost a little more. Definitely, do not want the blower itself to be a dud - any advice or insights greatly appreciated. Thank you!!!
