JoeLouis
- Jul 8, 2023
- South Atlanta, GA
I've been reviving an 84 242 GLT that had been sitting for over a decade outdoors. I have a hope of running the car in a 24 hours of lemons race. The car now runs, but the temperature is rising under spirited driving. I can let the car idle for an hour with the temp below half on the stock temp gauge. The car is modified and runs 15psi of boost at the moment and I took it for a 5 mile run, under accelerated driving, 80 degrees outdoors, and parked when the temp was about 3/4th of the way up. When I opened the hood I could see the exhaust was red hot on the turbo housing flange coming out of the manifold.
I flushed the coolant, and replaced, and did it again. Same thing. I have a new water pump, thermostat, and 2 row aluminum radiator installed but none are of high "racing" quality, and were inexpensive (just enough to get the car on the road). Two electric fans are running. The car had a brass, leaking, radiator core when I purchased, which I took to a radiator shop, but they said it failed the pressure test and was unrepairable.
As the 24 hours of lemons race is intended to be run with a 500$ or less car, I am wondering what angle to approach this from. A racing radiator, or an upgraded water pump maybe? Is there something I can source from a junkyard or will lowering the boost benefit me enough? I didn't plan to run it over 10psi for the race, but would like to otherwise.
As always, suggestions, feedback appreciated.
