Slight play on rear wheel bearings / clock clock noise
Bilbo19
France
Hey,
It's been a while that I have a "cloc cloc" noise at the rear end, on bumpy roads only. I inspected every bushings when the whole rear end was on the ground and everything seemed OK.
But I have a slight play at both wheel bearings, and I wonder if this can be the source of the "cloc cloc" noise?
Hey,
I had the same noise coming from the front bearings. When I grab the wheel and wiggle at tire it makes a noise. I had both front wheel bearings re-packed with grease and still makes noise over bumps.
Hey,
Is it possible your rear lower shock bolts aren't tight enough? I've had this exact issue multiple times as a result of the lower shock mount being able to move slightly under load. Impossible to move by hand and I couldn't even see it move when I had someone bounce on the bumper, but i could hear it moving. I loosened and retorqued them and the noise went away.
