smoothdurban
I do my own stunts
- Jan 4, 2013
- Kemble Ontario
As the car currently sits. See below for story and build progress.
Hello,
This is my thread in regards to my restoration of a 1983 volvo 242 turbo. Before I go deeply into the vehicle allow me to introduce myself
I am relatively new to this forum but not new to Volvo's or the restoration of them. My father is Viktor Zoldak owner of Zoldak Motors or "ZM" for short. His garage was formerly located on Highway 23 in Palmerston Ontario but it's currently in Windsor Ontario. My father Viktor has been repairing and working on Volvo's ever since I was in diapers. Needless to say I have learned a lot from him when it comes to working on Volvo's.
I have owned a variety of Volvo's throughout the years and my first build in high school was a 1969 1800s but I have owned several 200, 700, 900 series over the years.
But I have always loved the 240's for their simplicity and my current winter DD is my 1991 245 with over 372,000 km's (and counting)!
The car I purchased is a 1983 Volvo 242 turbo with intercooler. The car is silver with blue cloth interior and has an m46 transmission. The car belonged to a customer of my fathers who's original intent was to restore it. The car requires a considerable amount of cosmetic and mechanical work and after several years of ownership the owner finally decided to sell the car to me.
I purchased the car in July of 2013 with the plan to turn this car into my summer DD. The car ran poorly and suffered from all of the ailments a 30+ year car could suffer.
The plan I had was quite simple.
Strip the car, repair the rust, repair the engine, paint the car, and reassemble and drive.
below are some photo's of the car the day I brought her to the garage.
SPECS
B21FT Removed on 9/1/2018 with Low Compression after low oil
Kjet with UTCIS-PT WUR
Terminal 11 Trick
123 Distributor
Rebuilt T3 at 15 lbs
B230 Intake manifold
90+ Exhaust Manifold Milled and welded
Jao 3" downpipe to 2.5" Exhaust
HD Saab CBV
IPD turbo cam
KnockSense
Engine
Trans
<s>M46</s> Removed 12/19
Suspension / Drive Train
Brakes / Wheels
Interior / Exterior / Instrumentation / Electrical / Comfort
Hello,
SPECS
Terminal 11 Trick
123 Distributor
HD Saab CBV
IPD turbo cam
KnockSense
Engine
- B230FT out of a 1991 740 Turbo installed 5/25/2019 Machine by Tim Ferguson
- Rebuilt with 0.24? oversize Mahle Pistons and MaxSpeeding H Beam Rods winter 2018
- LH2.4 engine management with Sabbs Chips
- IPD Billet Turbo Cam
- Do88 Charge Air Pipes and Intercooler
- Do88 Aluminum Radiator
- STS Cam Gear
- STS Cooling Fan
- AutoCoolGuy Solid State Fan Controller
- 19T Water Cooled Turbo @ 18# Boost
- YoshiFab Vented Oil Cap & Catch Can
- Heavy Duty Compressor Bypass Valve
- Adjustable Fuel Pressure Regulator set to 2.8 bar
- GM Type II Power Steering Pump
- Wasted Spark Via Bosch 2x2 Coil Pack & Mitsubishi J702T Igniter
- Full 3" Exhaust w Jao?s Stainless Downpipe
- Innovate LC2 Wideband
- Bosch 0280155766 White Injectors
- Plug and Play Engine Harness from Dave Barton
Trans
- Tremec T5 Trans w DeeWorks Adaptor Plate
- 2.75? Drive Shaft from ShaftMaster in Allen Park MI.
- Yoshifab Billet Flywheel with FX250 235 mm Clutch
- STS Hydraulic Clutch Pedal
- Volvo 260 Hydraulic Clutch Master and 740 Slave Cylinder
- Hurst 8550 Shift Stick with 5 Speed Cue Ball Shifter
- Large Slip Yoke Ford F6ZZ-4841-BA 1330 to 1310 Slip Yoke.
- Yoshifab T5 Trans Cross Member
- 3.73 with G80 LSD
- IPD Pan Hard Rod
- IPD Gold Sways
- IPD Aluminum Skid Plate
- IPD Lower Chassis Braces
- BNE Hybrid Torque Rods
- BNE QSRC
- BNE Camber Plates
- BNE Sway Bar End Links
- BNE Rear Coilover Perches
- BNE Strut Brace
- GAZ Shocks Rear
- GAS Front Coilovers
- Eibach Springs 200# Rear 350# Front ~ Lowered 2"
- HD Reinforced OEM Control Arms PN Left 1229923 / Right 1229925
Brakes / Wheels
- BNE 302 / 316 mm Adapter Brackets
- Brembo Monoblock 4 Piston Calipers Front
- Brembo 316 mm Rotors
- BNE 20 mm Wheel Spacer Front
- BNE Extended Front Wheel Studs
- 17" Eiker E1's
- Innovate Wide Band AFR Gauge
- VDO Oil Temperature Gauge
- VDO Boost Gauge 0-25 PSI
- H1 & H4 Headlamp Conversion
- Working Factory AC
- LED Instrument Lights
- Fog Lights
- Wagonmeister Snow Caps
- Z28 Rear Spoiler
- Volvo R Sport Steering Wheel
- Blade Style ATC Fuse Panel Upgrade
- Recaro LsX Monza Blue Seats
