speedometers k39200 vs k40168
photoman327
North Alabama
what is the differences between the k40168 from my 93 244 and the k39200. the little plastic tab for the spring has broken on every on of the k40168.
One is for sedan(k40168) and the other for wagon. In a pinch you could use either one but if it's not the correct speedometer, speed will be a little off.
The Knumber is the number of pulses per Km expected by the speedo. Using a 40168 instead of a 39200 will read 39200/40168 = 97.6% of actual speed, e.g. the 40168 will read 97.6 Km/hr when you're going 100 (assuming you're using the factory tire size).
