So this post was from when I refreshed and upgraded the suspension: TME lowering springs, Volvo/Boge Turbo shocks, iPd sway bars, chassis brace and subframe braces.
... but I'll go ahead and hijack this post to tell the history of the car and to include the running tally of what's been done. I bought the car in Pittsburg, KS in March of 2013 with 91k miles on it; original paint and interior. It was essentially a one owner car. A couple had owned it and obviously fretted over the car. In addition to the low miles, it had a ton of records showing they took it in whenever it even made a noise.
One of the pictures emailed to me:
Shot of the car on the 5 hr drive home:
For whatever reason the car had sat for a couple years prior to being put up for sale. A well-known, regional Volvo guru had finally convinced the owner to let him sell it for them. I found out through the local VCOA chapter that a guy down near Springfield, MO had a clean, low mileage 940 turbo that he was preparing to sell. Since I had been looking for a cherry 940 wagon for years, I immediately reached out to him. He did some work getting it back on the road, but you could tell it had sat for a while. The intank fuel pump was dead and the brakes were rusted and warped. It also had dings on almost every body panel and a smattering of paint etching, clear coat damage and scratches. That being said, I knew the car could be really nice with some elbow grease.
I initially bought the car to be my daily driver, but soon decided that this car made a better basis as a project than my 1985 744t. As most of us know, Volvo addressed the biggest weaknesses of the early 7s in the late 940s (galv. sheet metal, beefier engine, G80, better wiring, etc). That and this car being a turbo and a wagon sealed the deal for me. After 20+ years, I sold the 740 in October of 2013 and this car took its place in the garage. I haven't regretted switching project cars for one second.
I've slowly been working on and modding this car the past 3+ years, here's a rundown of what's been done.
Maintenance:
-OE Volvo in-tank fuel pump
-Bosch in-line fuel pump and Mann filter
-resurfaced all 4 rotors
-OE rear pads
-Bosch FPR
-all vacuum lines replaced
-OE Volvo waterpump
-Stant 180 deg thermostat
-INA idler/tensioner
-Continental timing belt
-Continental drive belts
-iPd tailgate rattle kit
-driver's side power seat cable housing trimming
-full-car paintless dent removal
-Mobil 1 synthetic differential fluid
-Lucas synthetic brake fluid
-Bosch ignition coil
-full AC overhaul including a new OE Volvo compressor
-reman'd distro and fresh Bosch cap and rotor
-coolant flush (2x)
-GM Heater valve
-OE Volvo Expansion tank
-Zerex G-05 (HOAT) coolant
-Royal Purple coolant additive
-poly, outer stay rod bushings
-tie rod ends and ball joints
Modifications:
-15g (low mile Volvo rebuild)
-Kinugawa WGA w/ Mylesofsmyles bracket
-do88 intercooler
-Turbosmart e-Boost Street electronic boost controller
-AEM Failsafe Wideband (gauge/display is in a aaronllewellyn 3d printed vent pod)
-iPd turbo camshaft
-STS Machining adjustable cam gear
-Forge CBV
-3" downpipe
-3" Magnaflow cat
-2.5" catback (1 muffler)
-EGR delete
-ported ex. manifold
-Ostrich running a LH tune
-sbabbs EZK chip
-42lb/hr green giant injectors
-gutted airbox
-Yoshifab crankcase vent, can and vented oil cap
-VHT Wrinkle finish valve cover w/ polished letters
-Koni Sports front and rear
-TME sport springs in front
-Kaplhenke adjustable perches w/ 150lb Eibach springs in rear
-Kaplhenke QRSC's
-Kaplhenke adjustable sway bar endlinks
-iPd sway bars
-iPd adjustable panhard rod
-TME strut brace
-Cherry Turbos lower chassis brace
-960 subframe braces
-EBC Redstuff front pads
-iPd braided stainless brake lines
-Forged BBS RG-R wheels (17x8, 5x120, et40, 17lbs/ea)
-Motorsports Tech adapters (22mm front, 28mm rear)
-Michelin Pilot SuperSport tires (225/45-r17)
-OE Ecode headlights
-Eggcrate grille
-V90 taillights, hatch spoiler and handle
-V/S90 "Volvo" door sill moldings
-"940_TURBO" tailgate badge
-Euro side indicators
-Ambient temperature sensor/display
-850R Alcantara front headrests
-Kenwood Excelon HU
-Kicker CS series speakers front and rear
Stuff waiting to go on:
-M90 transmission
-Yoshifab billet flywheel/clutch kit
-FOHA Heckspoiler
Future mods?
-do88 radiator
-Some sort of brake upgrade, maybe?
-Deeper front spoiler
Maintenance:
-OE rear pads
-Bosch FPR
-OE Volvo waterpump
-coolant flush (2x)
-GM Heater valve
Modifications:
-do88 intercooler
-iPd turbo camshaft
-Forge CBV
-3" downpipe
-3" Magnaflow cat
-EGR delete
-sbabbs EZK chip
-gutted airbox
-Kaplhenke QRSC's
-iPd sway bars
-TME strut brace
-Eggcrate grille
-Kenwood Excelon HU
-M90 transmission
-FOHA Heckspoiler
Future mods?
-do88 radiator
