240 240
Millennium Falcon BIG BLOCK CHEVY SWAPPED
- Mar 3, 2022
- under the car
Shouldn't I be like 20-22 mpg combined?
light driving, 13c turbo spools super easy. last tank was 15mpg but driving harder to sort out issues and check new intercooler hoses.
When I was driving it daily in 2019-2021 it was about 19-20mpg which is closer to what it should be.
Basically did stage 000.
hoses etc etc. tires are stock hydras on whatever 205/55 tires. Car is slightly lifted. New hoses the whole thing.
15-40w diesel oil. trans fluid new 3 gallon flush. and 80-90 diff oil fresh.
new belts
plugs are light-medium brown. lighter than they should be but not terrible. never did distributor cap but looks good. fresh 8mm ipd plug wires.
compression is good. don't remember numbers but all cylinders even and no smoke under full throttle.
did seafoam 2x and it ran way smoother afterward
I haven't cleaned the tailpipe to see if soot is coming out.
O2 sensor works, but unknown age.
passed smog with flying colors after new cat. Car was super high Nox before the cat.
known negatives.
turbo has small exhaust leaks.
has a thule bars on it, so -1mpg?
lifted -.5 to 1mpg?
California Catalytic converters do a number on old cars. Maybe -1mpg?
california gas is garbage-1 or -2 mpg?
old cat was clogged after 10k miles. not terrible but enough to not pass smog.
My concensus Overview:
I need to really put a wideband on this to see what is happening.
Car shows slightly running lean but is it really? Or are there huge leaks and the fuel dumping is still slightly lean. There's really no or little pinging under load.
swap turbo for one that isn't leaking. This is obvious.
I think the cat is working too well. swap out for high flow outlaw cat and delete stupid rusty resonator for 1 muffler only to help with flow.
I ordered RBP stage 1 chips that brag slightly better mpg and a better map.
TLDR
Car runs super smooth, and plenty of power, but garbage MPG. Am I overlooking anything?
new belts
known negatives.
lifted -.5 to 1mpg?
TLDR
