stick70
All the gauges
- Sep 1, 2006
- North Carolina
I want to fabricate a new front crossmember including suspension for my 122 to fit the (unique) needs that I have for it. Can anyone recommend some study material that I can get into to familiarize myself on suspension design and geometry?
My goals here are to make the car handle well within the travel limitations that I have, as well as make the subframe more compact for the engine and suspension package I'm running.
Currently I'm travel limited, and this means I can't get the car as high as I really want to for an ideal ride height in the front. I've modified the front pickup points some to enable me to do what I can so far, but it's still not ideal. That and the subframe really does not jive well with the 960 oil pan in the car, and that makes engine removal an absolute bear. A couple of other positives of this will be rack and pinion steering, and hopefully more neutral handling. The car handles fine for what it is, but not as well as it can when set up correctly. Also if I can get a new front end under it I can make the car lay rocker when aired out.
The rear is a triangulated 4 link and is reasonable as-is, but I may be able to tune the bar angles when I deep dive into the theory of all this at the same time.
To be clear, I'm not looking to modify a kit or use a majority of suspension components from another car. I'm looking to design and fabricate a front setup specific to my needs. I'll select some components (rack, spindle, etc) based on what fits best, but the pickup points etc will be set by me.
Any help is appreciated.
