cwdodson88
- Oct 27, 2011
- The Dalles, Oregon
Svea - BOOSTED!!! - 1968 220 -
Ok, so I've never really done any sort of project thread so this can be moved to the showroom if it doesn't fit here.
I purchased a 1968 220 (Vin comes back as a 67, but registered as 68) from a local hot rod builder/mortician in 2005. I was 17 and had to make payments on it
that fits the tbrickers budget right?
He bought the car at a PDX swap meet because his wife liked the body. They started with a stage 0 attempt but she got tired of waiting and bought a Suby GT wagon. I picked it up for 2k and when I got it I found about 1.5k in parts inside. It came with custom lowering springs, kyb shocks and some extras.
I got it drivable while in college and beat the sh!t out of it for about 2 years. While doing all of that I managed to I mis read some SSA bs and racked myself into about 15k worth of debt with the feds.. So I stopped going to school and 7 years later I am finally getting to a point where I can bring this thing back to where I wanted it to be. Currently it has a b18 bored way out, don't remember how far (it came that way) b20 head, crane xr700 box, unknown cam, isky lifters and push rods, kybs in all corners, custom springs, M41 od trans, stock brakes and rear.
The build sheet (wants and haves):
Coilovers at all 4 corners - thinking of some Q1A double adjustables from summit, still doing the maths...
Wilwoods at all 4 corners (have adapters from Brick Autosport)
Ipd Sways Front and Rear (Front is on and rear is going in soon)
Looking to do a T5 swap
Keeping the B20, going +t Savar Turbo Style
- Have double valve springs, 3 angle head job, ported the exhaust at the valve seat, possibly going to weld the floors and reshape the port?
- B20 .040 pistons on the work bench with the block under said workbench waiting to be bored.
- Hoping to find a KG turbo cam, otherwise I'll have to see about having a custom one made up. Maybe a K cam if that doesn't work.
- SBC lifters and tubular pushrods (done)
MS2v3 - this will be getting ordered in the next couple months.
Winters Quickchange rear end - Still looking for one.
And I forgot to take pics of the car all together, but heres after some disassembly
some shotty body work!
Rusted window sills
Then in 2011 I bought a house, kinda sucked since I lost my garage, but I wasn't throwing money at the neighbor anymore! And it left me working in the driveway without a cover.
That's Dahla helping me adjust a fender. We just got her, she was 3 months old in that picture.
Some interior stripping and removal of the carpet underlayment.
Before:
and after some truck bed liner
Then the nose needed reworked
after a quick prime it got a test fit
Then the engine bay got stripped and primed
I moved and filled the fuel filler (I hated it when the gas attendant would leave and the nozzle would shoot out)
Then it got sealed and then body work and primer
Took everything apart after I wet sanded so I could clean it all again
I tried a single stage urethane since I had no where to paint except for the backyard, and no one would rent me their booth
Well that didn't go so well. Note to anyone who wants to paint outside in the summer, get a booth or climate controlled storage unit! Otherwise it looks like Rhino Liner! This mostly happened on the last coat. The first 3 coats went down smooth with decent flow out, but the temp took a jump from 70 to almost 90 in the recommended flaw time. So quick that I didn't compensate with my reducer.
some panels turned out ok, but it all had to come off.
so instead of respraying it outside I started the 2nd hunt for a paint booth and in the meantime I hit the engine bay with rhino liner
[IMGhttps://lh4.googleusercontent.com/L2a9o6MlePTczdd6DBp057MEa1nloipKu9bqcUzpBno=s196-p-no[/IMG]
And cleaned up the front suspension
I got a little artistic and drew up how I wanted it to look
Then found a garage that I could rent from a friends parents, so sanded the crappy paint down to "flat"
And rolled it into a garage that had pretty crappy lighting, but a decent exhaust setup.
and 2 coats of sealer going on again
Then a fresh coat of base
after 3 coats, my metallic really stood up
And smoothed out? this was while it was flashing, so about 5 min after the last coat. It still needed to flow a bit, but I can see myself!
Then the paint altering decision? How to two tone it? Well whats a 60's hot rod without some lace!
and heres how I did it?
Step 1: spray a perfectly good paint job.
Step 2: Ruin it! Lay a piece of lace, or drawer liner (the rubbery perforated stuff) or something else with holes in it over the perfect paint like so
if it doesn't hold itself on, use a non-permanent adhesive.
Step 3: Spray 2nd color over the laced portion, I used black lace and black paint, white lace would have been better so I could see where I was going? but oh well. Take plenty of time, and go super light and let it flash for 1.5-2x as long in-between coats.
Step 4: remove lace.
Step 5: Clear? and keep clearing until you have gone to the paint shop like 3 times
I put down 5 coats of clear to fill in where the lace was, so 3 coats of lace+5 coats of clear-wetsanding back to "flat" leaving maybe a coat of clear over the lace (luckily I didn't burn through) and then back for 4 more coats of clear so there is something to wetsand/buff.
Rusted window sills
Before:
