Swedbrick
- Oct 12, 2016
- Netherlands, Source of Grolsch
Given that my 745 project is close to the point I set out to achieve barring an upcoming turbo upgrade and according tuning, the itch for a new project has been there for a while. I'm also planning to move to a place where I finally have my own garage, such that I'd have the space to get into more welding and paint.
Initially I started looking for a daf 66 or a classic mini, but being tall and having way too many b230 parts already I ended up buying a b200k from a volvo 360 instead:
It came equipped with everything needed to swap it, including mounts, a different oil pan, a special water pump setup and and the potentially different flywheel?
These other bits came along with it as well, a full exhaust and plenty of spare parts
My inspiration will be these rad 343 rallycross cars, which were clearly awesome
I'd hoped to be able to just swap the bellhousing onto a 340 given the price/rarity difference, given the cool transaxle design used. But resident dutch 360 expert MrBorrie explained that this wouldn't work unfortunately, so I'm on the lookout for a 360.
Engine wise, the b200k didn't come with any reference as to where it came from making it hard to get approved, I don't mind since it has the center crank support anyway, and will be moving to a 90+ b230 block instead. I still have ITB's leftover, which in combination with some headwork, megasquirt/speeduino and a big cam should allow for some fun.
The chassis will get an assorted list of bits from ClassicSwede, to get it rally-spec for some forrest fun. A cage will also be added, as it is still build like a DAF, and is know for being crispy after some coastal seasoning. First thing first however will be to strip the b200k and pass it on
