Swedbrick
- Oct 12, 2016
- Netherlands, Source of Grolsch
Given the red 745 goes into winter storage each year, I decided I needed another project, and pulled this volvo 340 out of a field after sitting for 7 years. I looked at lot's of these over the past year, and this one was surprisingly rust free, given the track car was a horrid mess which I did not want to repeat. I'm the third owner, and actually drove it from where it was sitting straight to the registration inspection!
I did the usual once over, with fresh ignition leads, plugs and a rotor and cap. However the quality of parts available for these left me to go back to the original cap after buying 3! This thing has left me stranded quite a few times before I got it sorted.
For inspection the rear brakes needed a rebuild
And I found out that the starter solenoid stuck when hot, forcing me to destroy a battery as a fire was starting to happen after a 'mild' test drive where it got quite hot. I replaced the starter motor core with that of the stronger fast spinning 1.7 starter I found online, given it was in much better condition, and spins the 1.4 a lot quicker.
The small rust spot also got dealt with, given I was planning to drive this through winter.
Also got some AZEV A 15x7j wheels, and dented out the side of the car that got sideswiped when the previous owner still had it. New doors will be a future upgrade as the main support bar was actually kinked.
Long term I'm planning to swap this car with my spare b230FD, 360 sump and M47R transaxle. The original B14.4S engine is just as fuelly as my red wagon, at 1/3 hp and is quite a bit less smooth than even a b230. The 16v intake actually fits quite well in the 300 engine bay, so that's also on the table
