Citysurf740
- Apr 27, 2004
- Boston
hey any has the diagram to install the wires for revere.... thanks
This is my post for future searchage for people in the same situation. I'm adapting a 4cyl T5 to a b230f with an m40 bellhousing (upright orientation) for insertion in my '73 142.
I had an issue with the input shaft length of my 4cyl T5 being 7.41 as opposed to the preferred 7.18". I had stuck the transmission on the engine and it did bottom out before the bell housing mated. I actually had a 7.18 input shaft sitting around but alas the first? gear on the shaft was larger than that of the 4cyl shaft. So after a ridiculous amount of searching and no answer found, I took matters into my own hands and those of the chop saw. I took about .25" off the tip of the 4cyl input shaft and slapped it all together and it bolted up and verified that the 10 input shaft splines do not bind with the throw out bearing (when I put the tranny in gear and spin the output shaft, no clutch installed), which was a worry.
Am I dumb? Has this been covered before? All I saw on v-performance was mention that the pilot bearing was the same diameter of the 4cyl T5s. The other option was to space the adapter out .25" but that seemed like a lot of work lol I'm lazy. Now I just need to find a new input bearing retainer that doesn't exist!
A heads up, I know have t5 adapters in stock @ a reduced price.
http://www.kaplhenke.com/index.php?option=com_content&task=view&id=84&Itemid=32
I would be nice if you made a T5 bracket mount that would bolt up to the Volvo transmission cross member.
I am going to be making cross members.
Are the T5/TKO housing adapters good to run a 16v angled and or non angled? I'm planning to mount this engine non angled.
***********Nevermind I learned how to read.*******************
Answer is yes
does anyone do a T5 to whiteblock adapter (prefeably using an AW3040 bellhousing) ?
