turbojose
- Feb 22, 2009
- SF bay area
My tailpipe is always smoking and i'm finally tired of it. I have always just ignored it because its a 40 year old volvo. but today i have had enough. Some back story, i have a built 2.5 liter with only about 2000 miles on it. and It's a turbo car with a garette gtx3076bb turbo. this is with a 16v head and a 90+ manifold and 3" exhaust.
list of the important modifications:
1.) 16v head
2.) 2.5 stroker crank
3.) newly rebuilt bottom end (abot 2000 miles)
4.) head was rebuilt about 5000 miles ago.
6.) I run an oil restrictor for the turbo .035
7.) I also have turbo accusump booster accumulator
Some thoughts and things i have tried.
I run my crank case and valve cover gases to a catch can vented to the air with a combination of vacuum being pulled to pre turbo intake.
*I have been through three turbos thinking it was the cheap ebay turbos i was running but each time the same result... it still smokes. and the last turbo i purchased was directly from garrets not a cheap imitation, and still the same result.
I thought it may be my turbo drain back, but it is almost vertical, and -10AN line and fitings and flows great. non the less i have tried different hose and diferent fittings and still the same results.
the last set of plugs i pulled had oil on plug 3 and 4, so i was thinking i may have a ring issue. I ran a leak down test today, and the result were
#1 3% loss
#2 2% loss
#3 2% loss
#4 2% loss
so i was left stumped. the rings appear to be good, and no or gasket or valve issues.
I'm thinking it may be leaky valve stem seals, but not sure how to test for that.
and it makes me wonder if the head has valve stem seal issues, has that been ever since i hade the head professionally rebuilt?
any way long story short, i'm at a loss, and I just want to drive a volvo that doesn't stink up the road like uncle bucks 1980,s station wagon.
any one have any ideas they want to share?
1.) 16v head
#1 3% loss
#2 2% loss
#3 2% loss
#4 2% loss
