89-240gl+t
- May 7, 2012
- NorCal, CA
Are you running stock valve springs?
For sure thst! Thank you for your help.Great. That is cheaper than a turbo!
No. I’m running the ford valve springsAre you running stock valve springs?
Look at this nonsense.update... so I got the cam carrier off, and inspected all of the valve seals before i removed the springs, and you can see 11 of the 16 valve stem seals riding up high on the valve instead of all the way down where they belong. and after removing the springs, the seals were obviously the wrong ones. they are snug on the valves, but don't stay in place. Damn! i paid a place for a valve job several years ago, and I have been rolling like this for years. thank you all for your help. I'm sure my smoke will be gone once i get all of the seals installed properly.
Untitled by turbojose, on Flickr
So true! Thank you for your helpGreat. That is cheaper than a turbo!
thank you for this. I did use an installation tool and a hammer to put the new ones on. However all of the new ones were dark green in color. No contrasting ones for exhaust. Hope that doesn’t cause any more issues.@turbojose The 16v guide stem seals are pretty tight on the stems, the shop may have not installed them deep enough onto the guides as it can take some force if they are dry and not lubed... and they should be lubed.
Generally the gasket kits will come with two different seal colors, green and red/brown. One is for exhaust, the other for intake.
It's ok, if they were all dark green that means they were most likely viton which is what you want for a stem seal.thank you for this. I did use an installation tool and a hammer to put the new ones on. However all of the new ones were dark green in color. No contrasting ones for exhaust. Hope that doesn’t cause any more issues.
Common misconception on the exhaust not pulling oil past the guide due to positive pressure. B20 pushrods engines had stem seals from the factory on intake and exhaust, and 16v engines had seals on all valves from the factory. It's pretty common for 8v SOHC heads to burn oil past the guide in the exhaust even when the stem to guide clearance is in spec. I now run stem seals on both intake and exhaust with SOHC 8v 530/531 heads that I rebuild and haven't had any issues.Sure seems like it's pointing to bad valve stem seals. Normally, only the intake valves have seals because only the intake valves are subjected to vacuum that can pull oil past the seal into the combustion chamber. Exhaust valves are mostly under positive pressure.
Intake vacuum is highest on hard decel, and high at idle. Plus there can be some leakage when the engine is stopped with a pool of oil in the head above the valve.
I don't know if there's a simple test for stem seal leakage? Maybe do a leakdown test but crank it around until intake valve is open and block off the throttle body + hoses and listen for a hiss under the oil filler cap?
No problem.^^^ Thanks, I've been spreading the wrong information for many years.
Is there any way to check the valve-to-guide clearance without disassembling the head and special tools?
Untitled by turbojose, on Flickryes compression numbers were&#!%%!@ that sux! I forget, did the compression test numbers seem good? Leakdown was really good.
that's a good question. I'm going to drain the oil tomorrow and give it a check.Man catching up on this, does the oil smell really fuel diluted?
?Look at this nonsense.
The valve stem seals pulling off after having been professionally rebuilt.
