I just bought a manual 240 turbo wagon to replace the 940 turbo sedan that my wife drives. (I'm happy enough with the AW71 in my 764ti for now, but my wife demands a manual transmission.) Well, the clutch pedal is really stiff and engages really close to the floor. This was tuff240's brown wagon that I bought from jackbombay, and tuff240 had put a Centerforce clutch in it a while back. I'm starting to think that clutch may be on it's last legs. (I've already tried adjusting the clutch cable and can't get any better performance from it.)
As far as I'm concerned, that leaves me with a choice. I can either replace the clutch with a stock Volvo clutch or replace the entire transmission with a T5.
Either way, I'll be doing the work myself. I'm sure I can do either one (I've done all my own engine and suspension work for the last few years). The car currently runs a selectable 8/15 psi of boost on the B21FT. I know there's a danger that the M46 will eventually go.
With replacing all of the parts that could possibily be worn on the stock/CF clutch, I'm looking at around $500. With the T5 swap, I'm looking at more like $1500 plus the cost of the tranny. (That includes an aluminum flywheel from v-performance, an aftermarket shifter, bellhousing adapter, throwout bearing, pilot bearing, slider yoke, a custom driveshaft locally (estimated at a conservative $200), clutch, pressure plate, modified fork, and speedometer adapter.) My estimates may be a little high, but that's good, as far as I'm concerned.
So the question is: which should I do? If I can get all the parts together, it seems like an equal amount of labor to do each one, and the T5 swap has been tested quite a bit now. The T5 is more expensive, of course. Is it safer than the risk of sticking with a M46 that has an unknown number of miles left in it?
I'm leaning towards the T5, obviously, but I'd like to hear some thoughts from you guys. We've still got the 950 turbo sedan to drive while the swap is done, but I need to get the whole thing finished in the next two months, since I'm moving at the end of July.
Thanks,
Aaron
