You're supposed to crimp, then insert. You do need to pop the wedge lock out first, but don't pry on the little tabs... use the corners.I think I did the microsquirt connector wrong. I think you’re supposed to feed the wire through the plastic part of the connector then crimp and push it back in.
I crimped first then shoved it in. Now all my pins have rubber bits all wedged between everything. I’ve been picking it out with welding wire. It’s been a pain in the ass but I think that might be part of the issue. Doh
The AMP seal connectors are trash. They're cheap, which is why they're on everything.
There's like 7 on each tractor, I hate them.
