propav8r
F*ck Edgar
- Jan 17, 2010
- Franklin, NC
I can move it to Projects if you like.
Yes please.I can move it to Projects if you like.
Good idea. I found a momentary switch in my stash. I'll just do that.Little much for a coldstart don't you think?
When in doubt replace a human with anything cheaper
Those settings look fine - was the timing moving at all when you changed the Tooth #1 Angle? I'm not sure if it's needed, but did you do a Burn after every Tooth #1 change? Is your disc mounted as shown in the Official DSM CAS Guide https://turbobricks.com/index.php?t...-information-and-install-guide.224740/page-11So I tried changing the #1 tooth angle by 20 degrees over and over until I did the whole 360 and I never saw cylinder #1 come to TDC. What am I missing? Is it to 720? I’m confused.
Here are my settings.
Also I wanna say that ¢heebay bead roller did a damn good job
