The problem with Prv's
Ireland/Korea/Texas
Had to make another thread for this one as I'm ruining my original one with all the other vvos I pickup while building my 242 turbo.
Picked up this non running 1981 262c a few months back and started in on trying to resurrect it!
So far it's one step forward ten steps back !
I've replaced the main fuel pump, tank is clean, tank pump working, new fuel filter, fuel injectors are clean, fuel distribution unit seems to be working (depressing the air metering plate it springs back immediately,indicating the valve is moving freely).
Fresh plugs too!
She's running on starting fluid so I think the timing is ok.
Put some 108 octane into it last night with some premium and nowweve lost spark, think I've lost the ignition control unit now :) any pointers?
dl242gt
The world of the smiling Dogo
S NJ, a suburb of Phila.
The ignition is the bosch breakerless type similar to what is used in the B21F, and FT. The signal generating coil in the distributor likes to fail and can become intermittent failing when hot. You can ohm it out. I forget the specs but it's in books like the Haynes. Check it for the Volvo wire decay. The connector between the distributor and the ignition module can fail where the wiring enters the connector.
If you don't have spark it won't trigger the fuel pump relay with the coil signal. So, no fuel unless spark is working.
TestPoint
Ellijay
At least you have focused on the fuel system. The K-jet system does not appreciate storage and especially the fuel contamination that goes along with gas sitting for years.
The standard first place to start on the fuel side is the fuel pressure test since everything operates mechanically based on fuel pressure. Easy to say, a little harder to do. Start here: https://www.turbobricks.com/forums/showthread.php?t=289775
Most of what I learned in working through my Bertone that was stored 19 years in a hay barn. I ended up replacing everything from and including the gas cap and injectors.
Good chance that the O2 sensor is dead. New, it was a 25k mile maintenance item.
JohnLane
300+ Member
Northern Washington
OP if it has sufficient fuel check that the hose that disappears into a metal pipe under the airflow metering assembly is in place. One backfire and it gets popped out for a large ‘false air’ leak that will keep the airflow flap from moving for zero fuel to injectors.
TestPoint
Ellijay
Sorry to see it go but I completely understand. A 40 year old K-jet is something to fear.
Just curious, since I have one coming up for seperation; what did you get for it in Europe?
dl242gt
He probably got double in Europe for what he could get here. Even being dead kjet. They are probably gonna engine swap it. It looks good. Let me add that a 40 year old KJet PRV is something to fear. Those engines were a good idea but took too many years to really sort out the issues. Once they became B280s they were much better but no one wanted them by then and they were still to low on hp for the times.
JohnLane
300+ Member
Northern Washington
Bummer that Volvo didn?t turbocharge the even-firing three liter with hydraulic lash adjusters and the big oil pump. Could have easily been a 300HP/350lb/ft with a smooth idle that lived. Sigh.
dl242gt
I find it pretty ironic that Chrysler working with the French were able to come up with something for their cars that worked and helped John make a lot of power with his rally car. :cool:
JohnLane
300+ Member
Northern Washington
Rest assured that the only thing Chrysler added to the even firing three liter was the tiny throttle body that limited power to make the automatic fitted to the Eagle Premier/Dodge Monaco live longer.
