Swedbrick
- Oct 12, 2016
- Netherlands, Source of Grolsch
Hi All, Since I'm new to turbobrick I thought I would create a thread to keep track of my progress on my track/daily red wagon, for myself and those interested. Here's what has been done thusfar (Updated as of 1-2023)
The start
A clean 1986 Volvo 745GL with a b230k, pierburg (junk) carb and ezk118 and a m47 5-speed
The car as it sits now
Suspension upgrades
Shocks: Koni yellow shocks front and rear
Springs: IPD wagon lowering springs (-44mm rear, - 32mm front)
Swaybars: IPD blue 25mm up front, turbo 19mm on the rear
Wheels: Revolution Motorsport Millenium 7.5j front, 8j rear, et13 both
Tyres: Vredenstein Ultrac's 235/45r17 rear, 225/45r17 front
Brakes: xc90 T6 (336 front, 308 rear ventilated)
Camber mod, TXR anti bump and quicksteer plates, 960 braces, reinforced rear subframe
Racingdiffs LSD conversion in 3.54 ratio axle (940 48t with aluminium cover)
The current engine
B230FK, 9.3:1 ET pistons, Maxspeeding rods, squirters, KGtrimning 'strong' valve springs, port and polish 530 head , T cam, stock valves.
Hybrid 18T td04 hybrid with modified 13c compressor housing and 7cm3 conical housing.
LH2.4 conversion with redblockpowered stage 2 chips, buchka wasted spark, 470cc ev6 injectors
Engine build thread: http://forums.turbobricks.com/showthread.php?t=345333
The start
Suspension upgrades
The current engine
